Loader Brand of quick couplers found on Mahindra loaders?
   / Brand of quick couplers found on Mahindra loaders?
Can you post a picture? Are you sure its a male thread and not a short nipple?
What size is the male thread?
I believe this current problem (bad oil leak at one valve-coupler interface) is a repeat performance of a problem I had years ago... a bad o-ring. I am half going by memory/external inspection and half by the Mahindra/KMW parts diagram which shows elimination of the valve-to-coupler adapter on the last iteration of my ML112 loader. The value port size is SAE #6. The machine is not here at the moment so I can't snap a photo.
The thing is that I'd like a couple spare couplers as the machine is getting old and the couplers are starting to show signs of wear. I think that all will be well again for now once I change out the o-ring under the coupler and replace the internal o-ring and Teflon back-up ring too... but I won't be certain about that until tomorrow or Monday. :eek:
   / Brand of quick couplers found on Mahindra loaders? #12
Do you take the loader off and on a lot? Mine has been off one time, last weekend to replace a head gasket. I checked my couplers, couldn't spot a size on the female end. The male end was stamped NPT 3.
I almost never take the FEL off as I am using it constantly. :) Again, I should stress that I think (hope) I'll be back in business with just a little nuisance o-ring maintenance tomorrow or Monday. The spares are something I'd like to have here anyway... even if this latest event turns out to be a simple repeat of the prior o-ring leakage issue. :cool:
   / Brand of quick couplers found on Mahindra loaders? #14
That should be a stock item for KMW, I'm sure it isn't used exclusively for the ML112.
No, it isn't. My old ones have a different finish (kind of a gold-ish tint vs. silver) but the new ones on at least some of the current Mahindra FELs I've seen at dealerships are apparently the same type (male threaded o-ring connection) and brand ("Made in Italy" stamped on them same as mine).
Again, next time I find myself at a Mahindra dealership, I'll try ordering them based on a current production FEL and maybe I'll have more luck than asking about parts for a long-discontinued product. :)
   / Brand of quick couplers found on Mahindra loaders? #16
We source couplers from Faster. :)
   / Brand of quick couplers found on Mahindra loaders? #17
Did you try the part lookup yourself? I went through the New England tractor page, it is the only Mahindra parts lookup that I have been able to lookup online.
Go to this page: http://parts.mahindrausa.com/dealerview/Home.aspx
Then do a "Model Search" for ML112. You can also use NEW ENGLAND TRACTOR a division of Johnson Automotive Inc. and then click parts catalog.
It has five different versions of the valve system and parts, depending on serial number of our loader.
Ahhh! :) Thank you very much Jeremy! :thumbsup: It's been a while! :D
Looks like there is a Faster dealer not too far away from me although the male thread female couplings would be a special order. :eek:
For the record, I changed out all four coupler-to-valve o-rings and the leakage decreased about 97% (from constant flow to droplets), but it is still a problem and the poor old Mahindra's floor mat is practically ruined already. Hope I can find a replacement. I also replaced one internal o-ring & Teflon back-up in what was originally the suspect coupling but it didn't help. :confused3:
Next step? :confused: I'm not sure. With my aging eyes, it's not easy to see exactly where the remaining leakage is still coming from. :( Most of the leakage occurs while I am working the machine, not while the machine is parked where I could possibly see the source better. :eek:
At least I am pretty sure that the valve itself isn't cracked or damaged. That was a key concern of mine. I'll be able to take another look at it later this week and see what I can see. :cool:
All correct... and for the record, mine is the newest (i.e., last version that was manufactured) ML112 loader. :)
The first link doesn't work for me but I had done exactly as you described at that website several times. Unfortunately, the coupler in question comes up as unavailable when you try to order it. :eek:
   / Brand of quick couplers found on Mahindra loaders? #20
sometimes with the female side if the oring dryrotted its easy to get a piece still left in the grove when you install the new one... causing a very small leak
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2020 CATERPILLAR 239D3 SKID STEER (A52707)
2020 CATERPILLAR...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
