Loader Brand of quick couplers found on Mahindra loaders?
   / Brand of quick couplers found on Mahindra loaders? #1
Dougster
MA
2004 Mahindra 4110 w/509 BH
I'm sure this question has been asked many times before, but I can't seem to find the answer: What is the Italian-made brand of quick couplers used on Mahindra/KMW loaders? :confused: I know that both the older ones (like on my ML112) and the newest ones that I've been able to check still use the same "Made in Italy" brand.
What is that brand and where can I buy some exact replacements for the ones on my ML112? :confused:
   / Brand of quick couplers found on Mahindra loaders? #2
Iv ran into this many times I just end up ordering form Mahindra... expensive but will save a lot of time and headache
I've ran into this many times I just end up ordering form Mahindra... expensive but will save a lot of time and headache
I tried to do just that. My Mahindra dealer said that they are no longer available though Mahindra. :confused:
It may have been because he was looking specifically at parts for my 2004-vintage ML112. What I didn't try (and maybe should have) was to ask him to look up the parts for a current similar loader with same size couplers. :eek:
   / Brand of quick couplers found on Mahindra loaders? #4
lol no worries you have your loader S#?
These are the updated parts.. you should be able to find a coupler to fit in in to the valve if you have the one the quick connect come directly out the valve.
KMW05802106
KMW05802107
   / Brand of quick couplers found on Mahindra loaders? #5
Check with TSC or a local hydraulics shop to find compatible connectors.
   / Brand of quick couplers found on Mahindra loaders? #6
Pretty sure the Made in Italy ones are made by Stucchi: Stucchi USA
These are the updated parts.. you should be able to find a coupler to fit into the valve if you have the one the quick connect come directly out the valve.
KMW05802106
KMW05802107
Well, looks like you figured out why I want an exact copy of the original with the male thread to match the SAE#6 valve port. :) Yes, I'd like to replace the damaged one in kind and not have to use an adapter between the loader valve port and the new quick disconnect. :dance1:
Understood. No real problem finding compatibles in other brands as long as I am willing to use an adapter piece. But if I could avoid that by matching the original with the male thread, even if it cost a little more $$$, I'd be a happy camper. :)
I think you are probably right... and yet I can't quite match up any Stucchi quick coupler that I could find on-line to the OEM Mahindra/KMW part with the male thread. :confused: I can't find a Stucchi stocking dealer either so maybe best if I give a different Mahindra dealer a try. :confused:
   / Brand of quick couplers found on Mahindra loaders? #9
Can you post a picture? Are you sure its a male thread and not a short nipple?
   / Brand of quick couplers found on Mahindra loaders? #10
What size is the male thread?
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
UNUSED WOLVERINE MPF-11 2500G 30" PALLET FORKS (A57193)
UNUSED WOLVERINE...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2018 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T590...
2013 Ford F-250 Ext. Cab Pickup Truck (A55852)
2013 Ford F-250...
