Dirt Moving LS XR4155 more problems
/ LS XR4155 more problems #1
downs807
Lawrenceburg, KY
Kubota BX2680
Well tractor is back to having problems. Had a PTO issue a while back that I posted here. Ended up found that the wire harness had been rubbed by the clutch to the point it was shorting wires. Fixed the wires but now not even 8 hrs after I'm getting a F31 code which basically puts the tractor into a limp mode where it will only run 1400rpm. From what I can find it's the "foot pedal tract 2 fault". I've called the dealer and they ordered me a new wire harness hopefully that fixes my problems. 55hrs on this machine and so far I love it when it's working but the problems are getting old already.
/ LS XR4155 more problems #2
Like I posted in another thread I had a wire get cut by the HST pedal. Since then I wrapped the wire harness with a plastic shield. Seems their wire harnesses can get too close to moving parts.
/ LS XR4155 more problems #3
Good info, thanks for posting.
Cat 20 KW Light Tower (A64194)
Cat 20 KW Light...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
