Posthole Digger Post Hole Digger vs Bucket Spade for Pulling Small Trees
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #1
FreedomFamilyFarms
Auburn, IN
Kubota B2710, Toro Z Master Commercial
Hello TBN!
I'm planning to pull over some small trees on my property keep from leaving behind a stump. When I was a kid we'd use a PHD to auger around the tree roots and loosen the dirt before tugging on the stump.
I've been looking at PHDs and the best price I've seen is an older Ford 905 with a 12" auger for $350 on Craigslist. I'm wondering if a bucket spade might get the job done for a little less money and a bit more versatile tool.
Running a 27HP Kubota B2710 with loaded rears.
Thanks in advance!
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #2
Sounds like a certified pain in the butt. Screwing a PHD auger in among tree roots is not something I would do on purpose.
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #3
Can you define "little trees"? Also, are we talking mainly hardwoods (vs. pines)? Soil type and rocks?
I'm guessing you have a front end loader since you asking about a bucket spade... I've pushed over 12" dbh white pines that were 40 feet tall without digging.
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #4
I would have to agree with this.
Does the PHD come with a box of shear pins?
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #5
Why not a stump bucket? They work pretty good for small trees.
These are very small trees, less than 5" DBH. Soil is a solid clay. We did occasionally get the PHD stuck when using it to loosen dirt around stumps and yes, we kept a box of hardware store bolts and nuts as shear pins. The stumps and the tractor were much larger back then. It sounds like that approach may be overkill for this use case. I'll see what I can do to just push em' over with the loader. Any tips appreciated.
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #7
I've pulled over some "big trees" ("big" being a relative term, but way bigger than I though possible. ~ 18" maple & pines) by hooking a cable up as high on it as I dared climb (with a ladder).
The cable is also easy to rehook onto the root ball to pull out that last root(s) that remains planted on the side that the tree pivoted on. IMHO easier than trying to position the FEL to catch and pry the root ball to get that last root.
Also it keeps you and your shiny tractor away from falling trees and branches when the unexpected happens.
I also had the advantage of sitting on the tractor behind a protective screen/cage in case cable snapped. But a chain would work too.
"Give me a lever long enough and a fulcrum on which to place it, and I shall move the world." - Archimedes (c. 287 BC – c. 212 BC)
I have some cable I've used to direct larger trees when felling. How thick should it be to just pull one over?
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #9
I'll answer a question with a question: How heavy is your tractor? When pulling a cable that's attached to a point higher than the tractor, I don't think you can pull with more force than the weight of the tractor. Unless you get a running start (not recommended).
I'd compare the rating of your cable to the tractor weight and apply a generous safety factor. Typically, I'd think a 3/8" or 1/2" cable would be more than sufficient, depending on it's condition and construction. Especially if the tree tress are only 5" DBH.
   / Post Hole Digger vs Bucket Spade for Pulling Small Trees #10
It maybe be unnecessary, but are trees in a spot where you can soak the roots/soil prior to pulling? Rainy year?
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
44029 (A51692)
44029 (A51692)
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
30008 (A53424)
30008 (A53424)
2015 Chevrolet Malibu Sedan (A55853)
2015 Chevrolet...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
