HELP! Miller 211MVP Transformer Welder Quit!
   / HELP! Miller 211MVP Transformer Welder Quit! #21
...TF????
Sorry about that.
Terry
   / HELP! Miller 211MVP Transformer Welder Quit! #22
Taint you Terry, for some reason this thread is cuckoo... Steve
   / HELP! Miller 211MVP Transformer Welder Quit! #24
Mark, do you REALLY only wanna clamp that onto 1" or less? Read the specs on your link - even the 300 amp in that style (copper) only opens to 1-1/2" - I have a REAL Tweco (either 400 or 500 amp) on my old stick machine, it opens to just over 2" - and since I build a TON of stuff with 2" square tube and don't always leave an end open, that's MANDATORY for me.
For some of the smaller machines with their cheesy ground clamps I just went with the HF knockoff of the tweco clamps -
4 Amp Welding Ground Clamp
they will just barely clamp over 2" square tube, even though they only claim 1-1/2". I also bought a braided battery ground strap, about 14" long, and clamp THAT between the work and the clamp jaws (slight mod to one of Jody's tips and tricks, works GREAT)
Even the HF "tweco" beats the crap out of the cheesy things that get tacked on most welders these days, and they're only $14.
:2cents: Worth every bit of that :laughing:...Steve
"4 Amp" ground clamp? What's that for, tigging razor blades?
   / HELP! Miller 211MVP Transformer Welder Quit! #25
Dave, that's EXACTLY what it's for - ever try to put a full size ground clamp on a razor blade? :laughing:
OK, now the REAL answer - a lot of links tend to get zero's dropped - must be a glitch in code somewhere, but I see it a lot. That clamp's actually FOUR HUNDRED amp rated... Steve
   / HELP! Miller 211MVP Transformer Welder Quit! #26
I don't generally pick on such things, but I make an exception if it's funny. :laughing:
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
