Kubota L45
/ Kubota L45 #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
New to me and almost new anyway with only 75 hours on the clock. I ran across this L45 and decided I just had to have it. I already told on myself when I posted about the grapple that I got in the deal but I figured I would post a few pictures here. I ordered the forward hydraulics and when they come in I'll carry the L45 to the dealer and have a complete service done and the hydraulics installed.
/ Kubota L45
Having trouble posting pictures, I'll try again later :confused:
/ Kubota L45
I finally got some to upload.
20170712_095929.jpg20170712_095953.jpg20170712_100017.jpg20170712_100048.jpg20170712_100208.jpg
/ Kubota L45 #4
Get the fluid changed when you get the remotes. Nice but dusty tractor, Check the filters.
Space out the rear tires 1-1/2" to 2" per side and Load the tires about 1/2 to 2/3 full for about another 800 lbs for stability.
Have them check set pressures to the max of the spec.
Grease often.
Have fun, No Regen, yeah!
I can see by the wear that it is low hours, but whomever previously owned it gave it no TLC.
/ Kubota L45
Yep I looked at an L47 but the two main draw backs were the price and the Regen stuff, the previous owner of my L45 passed away and I bought it from his son.
/ Kubota L45
Here is a few more items I added to the deal, I think now I need some time use some of it.
20170707_121055.jpg20170712_175338.jpg20170712_175400.jpg20170709_112408.jpg20170712_175416.jpg20170712_175444.jpg
/ Kubota L45 #7
Nice tlb, I think you will be very happy with it's numerous uses and capabilities. I have found my 110 to be very handy.
The only thing you may not like is it appears to have a light materials bucket rather than a heavy duty bucket but I am not a Kubota expert.
/ Kubota L45 #8
It is The "HD' bucket
I welded a bit of extra metal to mine, side-plates, back scraper and more metal across top bar.
/ Kubota L45
what did you use for the back scraper?
/ Kubota L45
I have had a B26 for a while and have enjoyed it, I hope the L45 will be even better and now I have to adapt the things I built to fit the L45
/ Kubota L45 #11
If this is the heavy duty bucket then I would add the missing bolt on cutting edge to the front lip. Better to add it now before it gets bent up imo.
/ Kubota L45
now I got to look at the bucket a little closer and maybe add the cutting edge to it. Does anyone recognize the bush hog and know anything about them, it looked heavy duty to me when I bought it.
/ Kubota L45 #13
I used hard to find 2 x 2 x 1/2" thick angle and bolted to it a replaceable strip of 1-1/2 x 1/2 Steel. Decent for quickie grading, & Back Dragging, but a land plane is really much better. For the front I have a extra cuttng edge with ESCO teeth.
/ Kubota L45
Dropped the L45 off today to get the service and the forward hydraulics done should go pick it up Friday.
/ Kubota L45
went yesterday and picked up my L45 from the shop with the new forward hydraulics and a service done, came home and hooked up the grapple just to see how it works that thing is awesome even though I did not test it's limits I did pick up a big rock and then a crosstie.
/ Kubota L45
went out today to get rid of a recent dead tree.
/ Kubota L45 #17
L45 Is a great little mighty TLB, if serious 3 Pt Ag. type stuff in not your thing.
/ Kubota L45 #18
Hi Woody. Congrats on this great-looking L45!
Do you happen to know the dimension (or would you mind measuring) the total length when the backhoe is in storage position? I'm considering an L45 too, but I need to be sure it will fit in the dry storage I have available. Height is not an issue, but length is limited. TractorData.com tells me the length of this machine is 237 inches, nearly 20 feet. However I believe that is with the backhoe extended, like you would have it strapped down on the bed of a trailer. I'd like to know how long it is with the backhoe tucked against the back of the machine, as it would be parked.
Thanks!
/ Kubota L45
Thanks!
Yes I can when I get back home at work right now.
/ Kubota L45 #20
It’s 20 feet.... my l47 is the same and on the trailer (20’) the hoe, in the up position, is even with the ramps....
2012 BRENNER TANK PUP TRAILER (A67714)
2012 BRENNER TANK...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
More info coming soon. (A64557)
More info coming...
