XJ2025H won't run in two wheel drive.
   / XJ2025H won't run in two wheel drive. #41
I would tend to agree that it is rated under the 25 for emissions, and I've seen a higher rating on this- but I don't remember 30. In the Mitzi service manual they give a max RPM of 2730. One would assume that the governor can be fiddled with, but should it be? The Mitzi manual I have was something I stumbled on via the Googler. It does cover spring adjustments. Keep us in the loop.
   / XJ2025H won't run in two wheel drive. #42
I am seeing all kinds of different information out there on these s3l2 engines. There is a video on youtube with 30 hp @ 3000 and a couple pdf's from Mitsubishi with 28.17 hp @ 3000 and another doc from Mitsubishi with 27.6 @ 3000. Maybe they all have different internals but i would think it would be easier for Mitsubishi to make a one size fits all.
i wont hijack this thread any further so maybe i will start a new one to discuss these engines tomorrow.
   / XJ2025H won't run in two wheel drive. #43
When I was researching my purchase, I was led to believe that the Mitsu L3S2 in the XJ2025 was the identical engine from the XJ2030, but downrated from 27+ hp to 24.5 hp to avoid EPA requirements. In any event, these engines are used all over the world in all kinds of different applications.
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
