Safe way to change a belt on RCK60 deck on BX25
   / Safe way to change a belt on RCK60 deck on BX25
That's a clever idea!
As far as getting the deck in or out from under the tractor, I bought 4 of these to put under each anti-scalp wheel. Makes it so I can move the deck in any direction to line it up and not have to swivel the wheels. The cups in the casters fit the deck wheels just right. I drive the BX up onto a couple 2x8s to gain another 1.5" of height. A 2" thick board would be even better. Usually when mowing, I have the loader off, so can't just raise the front with the FEL always.
Shop Waxman 1-1/4-in Plastic Swivel Caster at Lowes.com
I will have to investigate that one too next time I have it out. That would seem to be fairly straight forward.
Just wedge a board against the idler and stretch the spring and start it on the far pulley and roll it on as I spin the pulley around.
David
   / Safe way to change a belt on RCK60 deck on BX25 #13
Not on this deck but on my 0turn, I used a rachet strap on the spring pulley.
This would seem to be the easiest way assuming there is a way to attach it without it coming loose under tension. The deck is now under the tractor so I cant try this. Tanks!
   / Safe way to change a belt on RCK60 deck on BX25 #15
The brake spring pliers work - I put a 1/4 inch bolt in the drain hole that is 2 inches "outbound" from the hook that the spring attaches to to anchor the end of the pliers. Leave the bolt half an inch above the deck so you can get a purchase with the pliers.
Great approach. This is going to be a great thread to come back to some day!
2014 BMW X1 S Drive 28I SUV (A56859)
2014 BMW X1 S...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
Forklift Safety Basket (A56857)
Forklift Safety...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
BEAIRD-POULAN 68 CHAINSAW W/ BOW (A58374)
BEAIRD-POULAN 68...
