DK4510 200 Hour Service Questions
   / DK4510 200 Hour Service Questions #11
I'd run it as is and change oil at next regular interval. Kioti recommended interval is very conservative and the equivalent of changing your car oil every 3000 miles.
   / DK4510 200 Hour Service Questions #12
Note for future reference; don't over tighten the pan drain bolts. They are steel on an aluminum pan, and can strip out fairly easily if torqued too tight.
   / DK4510 200 Hour Service Questions #13
I own a DK4510. My manual says the engine oil capacity is 2.4 gallons.
I an doing my first oil change.
When I changed my engine oil (and filter), I added that amount (2.4gal).
After running the engine for 10 seconds. Then for 5 min and checking the oil level, my dipstick indicates that I am way way overfilled.
I am now in the process of draining oil out, until i get the oil level down to the full mark.
What gives?
   / DK4510 200 Hour Service Questions #14
Let us know just how much you end up draining to reach the full mark.
   / DK4510 200 Hour Service Questions #15
I was only able to add 1.6 gallons.
I would love to know what others have run across.
I have a call into Kioti (Daedong - USA)
I'll post the results of that after I get an answer.
   / DK4510 200 Hour Service Questions #16
I just got off the phone with Kioti. (877.465.4684).
They say the manual is wrong.
While the printed manual says 2.4 gallons, the manual *should* say 1.58 US gallons.
Mystery solved.
   / DK4510 200 Hour Service Questions #17
Boy, you'd think Kioti would have issued a corrected manual or at least a sticky to put over the incorrect info in the manual. You can damage an engine with too much oil so Kioti really should be more proactive.
   / DK4510 200 Hour Service Questions #18
Quantity of old oil never seemed to match the manual's specs! ...I always pour slowly and go by the dipstick.
Alligator Statue (A55853)
Alligator Statue...
2006 KENWORTH T800 CRANE/DUMP BED TRUCK (A57192)
2006 KENWORTH T800...
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
UNUSED FUTURE FT-X-DM43 43" HYD DISC MULCHER (A57193)
UNUSED FUTURE...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
