New Holland TC30 Hydrostatic Transmission Making Noiise
   / New Holland TC30 Hydrostatic Transmission Making Noiise #1
justin2988
Texas
New Holland TC30
I was pulling a trailer behind my New Holland TC30 this morning, very heavy load going thru mud, tractor was having a heck of a time with it and I pushed it too hard. Transmission started making noise and I could smell a hot/burning smell, unhooked the trailer but tractor is now making a hissing/squealing noise when I accelerate over 5 mph in forward or reverse. It still seems to have normal forward/reverse power but the hissing/squeal is very concerning. Did I burn up the transmission? Any advice?
   / New Holland TC30 Hydrostatic Transmission Making Noiise #2
If it has the HST transmission I would start by changing the fluid and filter.
I've read this suggestion in a couple of other places regarding these hydrostatic transmissions. Could you explain why this is recommended? Is the idea that the oil got hot and lost it's lubricating ability or something?
   / New Holland TC30 Hydrostatic Transmission Making Noiise #4
You can overheat the oil and "burn" it so it loses lubricating properties. Hydraulic fluid should be clear. Pull the dipstick and check, it may smell burnt or have turned black. Even if it doesn't smell I would change it as you stated you pushed it too hard.
   / New Holland TC30 Hydrostatic Transmission Making Noiise #5
did you fix this problem?
2014 FORD F-250 (A50854)
2014 FORD F-250...
Rhino 156 Chisel Plow - NO RESERVE SELLING ABSOLUTE (A51039)
Rhino 156 Chisel...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
