RPM gauge stopped working.
   / RPM gauge stopped working. #1
Parfleche
WA
NH tc35a
Hello Folks,
My RPM gauge stopped working about 50 hours ago. What to look for for a fix? Thanks in advance.
Kind Regards,
Steve
   / RPM gauge stopped working. #2
Not that it is a fix, but out of the 10 or so tractors of various brands I've operated over the years, only two didn't occasionally take a few smacks with the palm of your hand on the dash to get it working. I think the needle just gets stuck from humidity and condensation and just needs a little shock to work free.
If a few taps of the hand don't get it working, I'd check out the wiring where it passes through to the engine. That is a common wear point for all tractors.
I've also seen cases of connections becoming oxidized inside of the various plugs and connectors. Disconnect the various connectors and inspect the terminals for any sign of oxidation. Spray them out with electronics cleaner and plug them back in. If you come across an oxidized connector, clean it up really good and be sure to use some antioxidant spray before reconnecting.
   / RPM gauge stopped working. #4
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2022 John Deere 6120M (A53317)
2022 John Deere...
PT 2 Row Plow (A53317)
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2016 John Deere 5075E (A53317)
2016 John Deere...
