JD 4600 - Instrument Cluster - Hour Meter Issue
   / JD 4600 - Instrument Cluster - Hour Meter Issue #1
rmonio
New Market, MN
JD 4600, JD B
Hello -
My JD4600's hour meter (in the instrument cluster) started losing it's display the other night and now it is no longer there. I've talked to the dealer and he said to check the wiring behind it (has anyone ever taken the cowling off to get to it?) or bring it in.
I'm curious if anyone else has seen this occur and what they did to address it.
Thanks!
-Bob
Thanks.
How do you get the instrument cluster open to look at it?
The threads talk about replacing it and losing the hours in it. I imagine that would be the same if I used a new one that the dealer put in.
-Bob
Thanks.
-Bob
I replaced the cluster and then disassembled the old one. Unless you're a electronics technician and good with wiring boards, it looks like you'll just need to replace the entire kit. I also noticed that the unit - once sealed to the hood - seals pretty tight. I'm thinking that the old one (which would fog up) probably had an integrity issue over time and that is what killed the unit.
Oh well. Money spent and on to the next project!
-Bob
   / JD 4600 - Instrument Cluster - Hour Meter Issue #6
-Bob
The unit ? That attached to the hood??
   / JD 4600 - Instrument Cluster - Hour Meter Issue #7
Informational Lot - Shipping (A57024)
Informational Lot...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
2015 Caterpillar 314E L CR (A53314)
2015 Caterpillar...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
