PT 422 hard to start
   / PT 422 hard to start
It sounded real sick to me. Don't forget to leave a section hanging out to remove it when you are done.
Well the cord worked fine. I ended up using about 3 feet of 550 paranoid. It did take two people to put the valve retaining clips back on. It still is not starting, so I ordered a new carb. Any other ideas would be appreciated. I also got some no ethanol unleaded gas.
   / PT 422 hard to start #22
Paracord, perhaps? :laughing:
Glad it worked for you on the valves. Bummer that it won't start yet. :(
Today I put on the new carburetor. I got it started but for the first start I had to disable the spark on one cylinder and then once it started I reconnected that spark plug wire. I have now started it about 10 times and while it did backfire a little through the carb, it started. I now am guessing that one of the coils is doing something strange and have ordered a new coil. The engine runs kinda of rough at idle. My guess is that the automatic spark advance on the bad coil is stuck on advance. At least I can use it again. I borrowed my neighbors mower with a Kohler engine and it started great. I talked to Terry at Power Trac today and they have PT with Kohler engines. They still have some left with Robin engines.
   / PT 422 hard to start #25
So the future for now is new Kohlers from PT?
That would be good news. Very few people in this forum seem satisfied with the Robin engines.
I think the Kohler is a really good choice for PT. It removes the weakest link in their smaller tractors. Terry says that they start much better.
I ran a test today and disabled one spark plug at a time. It ran worse on the side I suspect is a problem.
Bob, you should have done that earlier.
   / PT 422 hard to start #30
I didn't have the coin to drop a Kohler in last year or would have done so instead of a valve job on the Robin.
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Extended Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
Ford 8340 (A53317)
Ford 8340 (A53317)
