What is corn head grease and what can I use it for ?
   / What is corn head grease and what can I use it for ? #21
I almost think they plan for that wax to get hot and melt. :)
But yeah.. I use thin greas in those heads. remember the old worm drive circular saws. you put marine lower end lube in them. I don't remember looking at the bottles.. but I bet they were 0 or 00 grease too.
   / What is corn head grease and what can I use it for ? #22
Agree, I think that wax is supposed to melt and move around. Listening to mine that doesn't seem to work.
I wonder if fiberous wheel bearing grease would dampen some of the scream.
   / What is corn head grease and what can I use it for ? #23
I have an assortment of old angle grinders from way back pre harbor freight, back when the big thing was that traveling tool place.. can't remember the name. anyway.. homier? maybee?? I keep a bucket of old drills and whatnot.. lots of them chinese tools use a similar motor body and head bolt arangement, and you can do quite a bit of parts swapping. I've made put together tools like that. the bearings are always scarry crude, no wonder they scream. I see ball bearings where there should be needle or at least rollers.
When I rebuilt them old things I'd always pump them full of #2 amber wb grease. I have one grinder that is about ? 20 ys old now.. it actually still runs.. howls.. but now I can't get the old abrasive disc off. the rotor lock did long ago, and I had made up a tool to hold it, but the last time I changed it.. I have since forgot where I put it.
No prob. a year ago, HF had a tool sale. 4.99$ for grinders and 3/4 keyless chuck drills. I bought 2 of each. I'll break out a new one... bet it won't last half as long. :)
but yeah.. that orange brown grease they ship with is pretty horrible...
   / What is corn head grease and what can I use it for ? #24
I picked up 4 tubes of JD Cornhead Grease at lunch for my leaking rotary cutter. I was expecting it to be in pourable form from a bottle, not grease gun tubes. Counter guy acknowledged my application and said to pump it in with a grease gun. Did I get the right stuff?
   / What is corn head grease and what can I use it for ? #25
Yup. Buy a cheap extra grease gun at Lowes or HD just for the cornhead grease.
   / What is corn head grease and what can I use it for ? #26
I have one where I just remove the coupler when I need to fill a gearbox (putting it back on finger tight).
Aaron Z
   / What is corn head grease and what can I use it for ? #27
Yup, that's the right stuff
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
19088 (A55758)
19088 (A55758)
