Rotary Cutter Sharpening shredder, bush hog, rotary cutter blades.
   / Sharpening shredder, bush hog, rotary cutter blades. #21
Most of the time its the "hastle factor" that stops us from doing proper maintenance. Not a man here that doesn"t know they should remove the blades, inspect, sharpen, balance, etc. We're just too lazy and get away year after year with shortcuts. After having a tip thrown approximately 50 yards and come thru the side of our metal warehouse travelling another 40ft at ankle level before skidding and clanging into the front where I was standing I became a believer in doing it right. Get a setup that makes it simple and do it atleast once a year. Use a flap disk instead of an abrasive wheel and I bet you find it more manageable.
   / Sharpening shredder, bush hog, rotary cutter blades. #22
try to keep my fairly sharp on most jobs run the right rpms if your a 540 then run the rpms that is marked on your tach, its a lot eaiser on the drive train. I go thur a set of blades about every other year. I due a lot of brush mowing about 200 to 300 hrs a year at $45hr cant go wrong
   / Sharpening shredder, bush hog, rotary cutter blades. #23
That's what I'm talkin' about! :thumbsup:
I agree. It is designed to run a certain way and I think these guys running a geared unit with the pto going half way to where it is supposed to be is not good on the equipment. Not bad I do $60 an hour unless its a big job then I'll do by the job. Since we got some rain the last couple of years there is a lot of competition now. Probably the same for you since doesn't seem your that far away.
I have a extra rotary cutter.......I was thinking of replacing the blades with chains.......Thoughts?
   / Sharpening shredder, bush hog, rotary cutter blades. #26
I think after awhile, if not sooner, you will start throwing chain links at 10000-15000 fpm out from under the deck and on to God knows where.
   / Sharpening shredder, bush hog, rotary cutter blades. #27
Ye-ouch! Bad enough to have the occasional rock fragment whack me in the back of the head. A piece of chain would be a major headache.
............Didnt think about the links coming off.
I did see some pictures I think is france or spain where I THINK they actually sold rotary cutters with chains instead of blades.
   / Sharpening shredder, bush hog, rotary cutter blades. #29
I suppose you could do that, or even use appropriate-length pieces of steel cable (like a really heavy duty string trimmer!)...but, even without considering any additional hazard, what is the advantage over the blades?
Heavy Duty String Trimmer.........WHOA!!! That would be massive.
Man Basket Forklift Attachment (A55851)
Man Basket...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2008 Geringhoff NS800 8R30 Corn Head (A53485)
2008 Geringhoff...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
