AR15 Sling Advice
   / AR15 Sling Advice #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I bought a Mossber AR15 a few months ago and am looking for sling advice. This had the M-lock fore end on it but I think I just want a 1 point sling. I also wonder how you hook this up. A lot of the pics seem to show a bracket installed between the buffer tube and the receiver that has a hole in it for the sling to hook into. How do you install this bracket? I can find all kind of info on slings but none that really show how to hook it up to the rifle.
   / AR15 Sling Advice #4
Make sure you stake the castle nut when you finish.
   / AR15 Sling Advice
Thanks for the links. I wasn't quite searching for the right thing in google and didn't get the results I wanted.
   / AR15 Sling Advice #7
How do you unstake a castle nut?
Pull hard with your armours wrench (spanner?:laughing:) and tap the end with you plastic hammer
   / AR15 Sling Advice #8
I did and it still won't budge. Even broke one mounting block.
   / AR15 Sling Advice #9
Take your dremel with a very thin slitting wheel and relieve as much of the staked deformed metal as you safely can. Then put on your armours wrench/spanner, and put some down pressure and hit the end of the wrench with your plastic hammer to offer some impact. Impact will always loosen things that pressure wont.
   / AR15 Sling Advice #10
Thanks James, I will try that.
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
PENDING SELLER CONFIRMATIONS (A56138)
PENDING SELLER...
2021 BOBCAT T740 SKID STEER (A52706)
2021 BOBCAT T740...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A56129)
2020 INTERNATIONAL...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
