3-Point Hitch 3 Point Hitch not working
/ 3 Point Hitch not working #1
Puebloswatcop
Fountain, Colorado
Farmpro 2430
I recently had to replace the clutch in my Farm Pro 2430, thus had to break the tractor. Drained and replace all the hydraulic fluid. Cleaned the screen while I had the hydraulic tank open. After doing all of that there seems to be good flow to the front end loader hookup points. Problem is the 3 point hitch will now not lift at all. Any advice on what to check?:banghead:
/ 3 Point Hitch not working #2
You say the loader works, but the 3PH dosn't? Does the engine load down when you try to lift the 3PH? Could the speed regulator valve in front of the seat have been screwed all the way in? That would keep the hitch from lifting(or lowering) and would cause engine to load when trying to lift as the pressure builds to pop the pressure regulator back in the 3PH control valve...
Got it figured out, One of the hoses was blocked. Thanks for the input.
2025 Mini Excavator Rake Attachment (A64553)
2025 Mini...
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A64194)
Pemberton Inc...
INTERNATIONAL 5300 END WHEEL GRAIN DRILL (A64278)
INTERNATIONAL 5300...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
