John Deere 5055e clutch slipping.
   / John Deere 5055e clutch slipping. #1
chaploneywj
Gouldsboro
New Holland
Hi All, I have a 2014 5055e. At 350 hours the clutch started slipping. I took it to the dealership they kept it for over a month. When I went to pick it up, they told me it was an adjustment. As he realized what he said he corrected himself and said "Lots of adjustments". Now at 450 hours of use its slipping again. The clutch pedal is also grabbing and then releasing. When this happens the PTO lever jumps a little. The tractors main use is loading and unloading round bales. Before this I had a NO tc55. It had over 2000 hrs with no clutch issues. I'm confident it's not caused by me. The dealership is telling me to adjust it myself. My questions are 1.Is it normal to have to adjust a clutch every 100hrs? 2. Has anyone else had this problem? Any info would be helpful. Thanks.
   / John Deere 5055e clutch slipping. #2
Is your serial number a 1LV or PY?
Thanks, would the s/n help?
1LV5055HAD4240119
   / John Deere 5055e clutch slipping. #8
So ...at 350H you allready coocked the clutch ! Always remember to check the clutchpedal for freetravel !
   / John Deere 5055e clutch slipping. #9
Sounds like the 9/3 trans right? That one is a dry clutch vs the wet in the 12/12 power reverser. If they already completed lots of adjustment how much do they expect there to be left? Sound so like it was placed on the back burner and forgotten then rushed thru to get it back after they realized you were still hanging. Good luck and hopefully splitting it isn't in your future.
Brett
If this is the case why is it not in the periodic maintenance section of my manual?
TAKEUCHI TL8 SKID STEER (A51242)
TAKEUCHI TL8 SKID...
2024 MERCEDES-BENZ SPRINTER 3500XD BOX TRUCK (A51222)
2024 MERCEDES-BENZ...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
