155d slow throttle response
/ 155d slow throttle response #1
chevy791979
white heath IL
155d yanmar
New member here. Just got a sweet deal on a 155d with 280 hours on it and was a 1 owner. Runs good but the throttle response is slow. Any thoughts?
/ 155d slow throttle response #2
More information, slow with load, slow no load? All linkage free?
Slow no load. All linkage is free. Smokes like to beat the band. Lol. It's not the air filter. This tractor only has 280 hrs on it original. Sweet looking tractor. Almost too nice lol. Just hasn't been used much
/ 155d slow throttle response #4
Is that a 3 digit hour meter?? Could be 2280 hours if so or anything like that...3280?
Possibly clogged fuel filter? Injectors?
/ 155d slow throttle response #5
What about the fuel? If it has been sitting a long time it might have contaminated fuel. Or, if it is like around here, it might have a whole community of mud daubers living in the muffler. :)
/ 155d slow throttle response #6
Aaron is onto something maybe?
Pull that muffler and manifold off the head and run it and see if there is a difference
/ 155d slow throttle response #7
How do you know the throttle response is slow? Compared to what? You start at full throttle and can easily back throttle off to idle before it gets anywhere near full RPM.
/ 155d slow throttle response #8
Has anyone had the injection pump off?
/ 155d slow throttle response #9
When cold how does it start up? Quickly? Having to turn over for more than 20 sec.?
Does the engines rpm fluctuate?
Does it have fresh fuel?
Starts good for the most part. Compared to other 155 videos I've seen mine fires slower than others. Rpm is smooth.
I doubt this is the case for the fact it was in a nice new shed it's whole life but definitely worth looking into. I bet my borescope would fit down the pipe
/ 155d slow throttle response #13
Yep fI you have one it would. Most of us don't so we just take off the 4 nuts in like 5 minutes including finding your tools.
/ 155d slow throttle response #14
"Smokes like to beat the band." What color smoke? Constant? What about blow by out the crankcase vent?
Zero blow by. Black smoke it is starting to get better the more I use it. I put a good healthy dose of injector cleaner though it and seems to be helping. Honestly I bet the injectors are full of old fuel deposits.
/ 155d slow throttle response #16
Black is too much fuel. Do the injectors look like they have been messed with? Wrong ones put back in , maybe?
This tractor has not been touched. As soon as the engine catches up with the governor demand it cleans up but 1st gear in high range it won't hardly climb a slight hill.
/ 155d slow throttle response #19
Would it be possible to do a video with it in the pulling mode?
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2019 HINO 268 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 4X2...
207923 (A63290)
207923 (A63290)
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
