2555 Tie Down points
/ 2555 Tie Down points #1
Glrret
Somerset County, Maine
Mahindra 2555 Shuttle
I was wondering what other have done to secure their tractors to a trailer for transport, the 2555 doesn't have a very good place to attach chains to.
/ 2555 Tie Down points #2
How far are you going? If were just running a few miles down the road we run a clevis through the rear hitch and a chain through it to the corners of the trailer and another through the FEL and cinch it down with a chain binder or come along.
When I take it to the fields its not a big deal, but when I run to the dealers its a 65 mile trip on I-95. there is a DOT weigh station on the way and I've been lucky so far and they have been closed. I know DOT doesn't like chains going through the FEL, they want them on the frame. A friend of mine has a New Holland and he had a large chain loop welded to the front of the frame. but the 2555 doesn't have s good place to weld to for the same type application.
/ 2555 Tie Down points #4
^^^agree... my susestion wasnt for long hwy way speed trips.
/ 2555 Tie Down points #5
This is what I did. It's nothing special but good enough to make it to the dealer if I have to.
/ 2555 Tie Down points #7
Yes, I just drilled out a hole and added a grade 8 bolt. You could probably weld some on too.
Do you cross your chain when you tie it down?
I do the same thing on the drag link as you, I have a 1/2 twist clevis.
/ 2555 Tie Down points #10
Front tie down.
/ 2555 Tie Down points #12
/ 2555 Tie Down points #13
loader cross member under the front and then get you a clevus for the back
/ 2555 Tie Down points #14
I wouldn't trust the grill guard for a true tie down
I was thinking of using the same type tie down ring that IH782 used but to weld them to the front of the frame as indicated in this picture. Do you think the frame is strong enough there?
/ 2555 Tie Down points #16
Shouldn't be a problem if you have to have 4 points. That what your going for? We just use two cross chains
When you say 4 points do you men 2 in the front and 2 in the back? I planned on 2 in the front and a clevis in the drag link in the rear.
/ 2555 Tie Down points #18
Like 4 chains and 4 booms... some DOT require it
I don't have any idea were I could connect 2 chains in the rear.
DO you have any suggestions?
/ 2555 Tie Down points #20
you would have to have hooks built for your trailer floor but the loader frame below the cab is a good point.. I usually just do what your talking about with one chain then the other on the cross bar for the loader brackets in the front... wish they all had the front towbumper like the 5500 series and Mpower series has... makes life easy
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2014 Ford F-550 (A55973)
2014 Ford F-550...
New/Unused Landhonor 50 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
