Quick attachment system
   / Quick attachment system #1
Lilguy
Chicago, Illinois
Kubota
Is the Kubota system an industry standard? Will I be able to use attachments from other manufacturers. Will skid steer implements work with the my Kubota 2601?
   / Quick attachment system #2
According to what my dealer said, was yes, they will attach, but i have no proof of it to be true because i dont have any other attachable front implement`s besides the bucket that it came with.
   / Quick attachment system #3
If it is the SSQA quick attach which Kubotas is then all SSQA implements will fit. Two slots at the top, two lift handles that lock two pins at the bottom.
Kubota had/has a Kubota pin system that isn't the same as the SSQA system but most newer Kubotas use the SSQA system which costs a few bucks more.
   / Quick attachment system #4
This is the SSQA plate that is on an attachment:
This is a SSQA mechanism:
Both together:
Loader with SSQA:
I want to get a pallet fork for it. Kubotas is $1200.00 from local dealers, 6-800 dollars from other manufacturers. Will any one here recommend a name they have experience with?
   / Quick attachment system #7
Is there an easy place online to get the part # and price for that Kubota SSQA (loader side) for an older Kubota? I have a 95 L35 I would like to upgrade. Thanks
   / Quick attachment system #8
Unless you use the SSOA alot, and have many different implements for your FEL, i dont see the expense working very well in your favor, cost vs time.
   / Quick attachment system #9
I only have the forks and bucket and I find myself switching often I am so glad that I got it when I bought my tractor. I almost did not because I was cheap but the dealer talked me into it
   / Quick attachment system #10
I like mine, glad i bought the optional SSQA with the BX23s tractor. It opens up many different options to buy more quik-attach things... oh noooo, there goes my dang wallet...lol. I`m looking into the pallet forks, and the sno-pusher right now. I only want things that i`ll use all the time. I dont want a back yard full of frontend attachable implements that only get used once and then sit there until i realize i shouldn`t have bought them. One expensive frontend item comes to mind, the grappler... i cant see the expense, and it would get used once and never used again. Not to mention, i would have to add the third hydraulic, thats a pricey option for how little i would use it. Not worth it to me.
CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
CATERPILLAR D3 LGP...
2461 (A58376)
2461 (A58376)
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
International 656 Utility Loader Tractor (A59814)
International 656...
