Bro Tec in Canada is the premier supplier. Very high quality material and workmanship.
Three inches wider on each rear wheel will cost about $300 in Bro Tek parts, plus local installation.
Do not fill tires AND add wheel weights with spacers. One or the other, not both.
LINK: Bro-Tek
LINK: Bro-Tek
THANKS!
$300 for spacers seems a little high when you think about it. Surely someone else makes them at a better value. Hoping someone else found them a little cheaper.
Also not exactly how wide i want to make this machine. My goal is to make it more stable when going sideways on my hill. I'm thinking 2.5 per side would be nice but i hope it won't be too wide.
THANKS!
There have been a couple threads posted where wheels failed with spacers + liquid in tires + iron wheel weights in triple combination. OP specified he needs to mow across slopes. Strain on downhill wheel will be heavy, perhaps double strain on level ground, perhaps MORE. Add in liquid and cast wheel weights and there will be a very heavy load on downhill spacer. This is a SAFETY issue with potentially mortal consequences. Not prudent to explore close to boundaries. OP's "B" has a lot less beef than your "L".
There have been a couple threads posted where wheels failed with spacers + liquid in tires + iron wheel weights, in triple combination.
OP specified he needs to mow across slopes. Strain on downhill wheel will be heavy, perhaps double strain on level ground, perhaps MORE. Add tire liquid and cast wheel weights and there will be a very heavy load on downhill spacer. Should tractor begin to roll, liquid tire ballast will shift, making roll inevitable.
