Rear Blade Rebirth of Rear Grader Blade Project
   / Rebirth of Rear Grader Blade Project #1
The Deerslayer
Northeastern CT
Kubota L3901 Former: Kubota L2250
So I finally took the time to take a stab at revitalizing my old and rusted grader blade. After grinding the rust off, I applied a few coats of primer followed by spraying on two top coats. For my first implement refinish project, I'm fairly satisfied with the results. As I primarily use the blade for snow removal, I may add a wax coat to the blade on both sides. Thought process being that the wet snow will be less likely to stick as it did to the rusted finish the blade sported prior to this project.:laughing: We'll see.
Here are a couple before and after pics:
   / Rebirth of Rear Grader Blade Project #2
Looks good - I have to force myself to paint. And it never comes out that good. You did a nice job there.
gg
   / Rebirth of Rear Grader Blade Project #3
my fingers just cringed in pain as the thought of trying to touch that blade in the sun. looks nice! just different color please, your 2nd degree burns will thank you later ;)
gg
Thanks, I'm the same way with painting. Got a cheap spray gun from Harbor Freight, and it worked like a charm.
I hear you! I actually had the orange paint bought and ready to use. Took it back because I figured the black would be better when it gets all nasty and dirty with manure. Being that I mainly use it in the winter time, I'm not too concerned about the burn factor. In fact, it might be a plus to warm my hands in the winter!:laughing:
   / Rebirth of Rear Grader Blade Project #6
Nicely done :thumbsup:
" Thought process being that the wet snow will be less likely to stick"
Getting ready for winter already. :eek: ;)
Update: After waxing the blade as I noted earlier, I probably would not do that again. Probably more trouble than its worth, winter will tell. Being that the surface is not totally smooth like a tractor or car, the wax tends to get into the little depressions and remain. No big deal I suppose....it is just a tractor implement after all!! :D
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2015 Nissan Sentra S (A50324)
2015 Nissan Sentra...
Ideal Applegate 180 gal Water Trough (A50515)
Ideal Applegate...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
