6000 will not turn to left
/ 6000 will not turn to left #1
SO3
Austin
Mahindra 6000
I own a Mahindra 6000 that will not turn to the left. I have replaced the steering cylinder, to no avail. The fluid seems to be seriously overheating and I have now noticed power steering fluid coming from the steering column. Could the reservoir be stuck or bad? What is causing the overheating? Could there be a stuck valve or bad pump?
I have no idea what to do next.
Thanks, in advance, for your assistance!
/ 6000 will not turn to left #2
There is a valve of some kind on the steering column. Follow the lines to it. That is where the fluid is directed left or right and how much goes in each direction. I am no hydraulic specialist but you can start there. Maybe someone with more knowledge about it can chime in.
/ 6000 will not turn to left #3
Is your 6000 a 2WD or 4WD? How about the fluid level in the res? BobG in VA
/ 6000 will not turn to left #4
In the steering column there is what is called an orbital valve. The orbital valve (steering control unit) directs hydraulic fluid to either end of the steering cylinder depending on which way you want to go. It's obvious that the so called orbital valve has packed up on you since you've already replaced the steering cylinder.
Pirate4x4.Com - Extreme Four Wheel Drive
I guess it's a good thing that I was into rock crawling before I became a tractor owner. When things break down on you when you're way off out in the boondocks, you've gotta either fix it yourself or walk.
The 6000 is a 2 wheel drive. hanks for your time and knowlede.
/ 6000 will not turn to left #7
Whether it's two or four wheel drive, it doesn't have anything to do with the steering. The basic steering system is the same for either. Since you already have fluid leaking out of the orbital valve, start there. It's either the valve or the plumbing to it but since it's leaking it's likely the valve itself.
/ 6000 will not turn to left #8
The 4wd had a better HSU unit... but a smaller cylinder.... and the 2wd had a common problem of HSU units and also the tire spindle freezing up inside the axle
2018 Chevy Traverse 3rd Row Seating (A63118)
2018 Chevy...
Coyote Renegade Trailer (A63116)
Coyote Renegade...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
832654 (A61165)
832654 (A61165)
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
MANCHESTER 80 GALLON AIR COMPRESSOR (A62131)
MANCHESTER 80...
