TheJackal
I bought a finish mower today. Think I got a decent deal on it. ($400) I'm experienced enough with my tractor to know that I don't know much and don't want to do something stupid that will break me or the tractor.
Here's the deal. The PTO shaft on the tractor has a slip clutch that extends the length of the PTO away from the tractor by enough that the driveshaft on the finish mower is too long for my lower lift bars to fit. It appears that if I removed the slip clutch, the mower would work with no modifications needed at all.
My questions are these:
Should I remove the slip clutch? I don't anticipate running 3 point equipment with this tractor other than the finish mower.
Should I find longer lower lift bars? Looks like I would need 36 inch center to center. My concern is that pushing the mower further back might be less safe. As a practical matter, the property I am mowing adjoins my house so there will be no need to lift the mower to move it to where I mow. It can just roll on the four leveling wheels.
Should I find a shorter or shorten the drive shaft? My concern here is the clearance between the mower and rear tires would be reduced. It might be enough to have no problem as long as I have the stabilizer bars sufficiently snugged up.
The tractor is my little Iseki TU1700 (that I've got about $500 in). The mower is a Del Morino SRM150 (about 60" cut).
Thanks in advance for any help you can offer.
Ben
Ben
