Oil & Fuel FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw?
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #11
I have heard that you can't go back once you use synthetic oil in an engine. Would this hold true for a two stroke also?
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #12
I use a slightly heavier mix, around 45:1, can't remember if i bought synthetic last time, I found my saws ran better on the homelite oil than they did on the Stihl oil I had, I ended up mixing the two bottles together.
I wouldn't see why synthetic and regular oil would be any diff on mixtures, it's not like I add less full synthetic oil in my car, it's the same amount.
I always buy premium gas only because it takes a lot of cutting to burn even two gallons, my MS-660 is a bit more thirsty than my Husqvarna saws but the 192 tc and the 660 is the only two saws I carry now. I gave away my Husqvarna 262xp.
If you don't have a little saw like the 192 tc pick one up, I use it for anything under 8-10inches. It's great.
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #13
I have a couple grand tied up on Stihl saws them add up the blower and weed eater. I buy the 2.5 gallon oil mix in the gray bottle. Put that with 2 gallons of super unleaded. Never had any issues. These saws can sit for several months at a time and they alway start. Blower was bought new in '09 with weed eater. All original. I love my stihl stuff
Brett
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #14
Brett
What weed eater do you have? I was thinking about buying one this year. I saw a Stihl weed eater in rural king but it looked pretty flimsy, they only wanted $160 for it though.
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #15
Brett
I also have Stihl chainsaw, blower and weed eater. Very happy with every one.:D
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #16
I have one 2-cycle engine, a Stihl MS-261 chainsaw, the smallest saw in Stihl's professional grade offering.
Per instruction, I use (Chevron) 87-octane mid-premium gasoline in this saw. Gasoline contains 10% ethanol in Florida.
Until yesterday I have used Supertech (standard) 2-cycle engine oil, mixed 50:1. Cost $1.64 for 6.4 ounces.
One gallon of chainsaw mix lasts me three weeks.
Yesterday purchased Supertech FULL SYNTHETIC 2-cycle engine oil. Cost $2.64 for 6.4 ounces.
Should I maintain 50:1 gasoline : oil ratio?
Generic directions on Supertech container say: "Always follow manufacture's recommended mix ratios for optimum performance and protection." Stihl offers no guidance for FULL SYNTHETIC oil in 2012 edition of MS-261 Owner's Manual.
I buy chainsaw gasoline one gallon at a time. 50:1 ratio is 2.5 ounces of 2-cyle oil per gallon of gas, so a 6.2 ounce container mixes 2-1/2 gallons of chainsaw gas.
Will I notice a performance or longevity improvement for my extra $1.00 per container of FULL SYNTHETIC 2-cycle engine oil?
Other considerations?
I operate in Florida. No cold temperatures.
I have a lot of Stihl equipment between chain saws and brush cutters. None of the manuals say anything other than minimum 89 octane. I definitely would not be using 87 octane in my 2 cycle engines. Maybe Stihl has changed their octane spec but doubt it.
Look at your manual and verify.
Just looked at the Stihl website and they are still stating 89 octane. Yes they state 50:1 for synthetic.
You are not doing your saw any favors using 87 octane. Ethanol has issues as well especially if you do not use it quickly. Some define quick differently.
Look at buying ethanol free. Yes it cost a bit more but you are not burning much gas at the quantities you say you use.
Ethanol free gas in Florida
Your saw is an investment treat it as such and it will last a long time.
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #17
FS90 if I was to do it again, I'd go with the fs110. Never heard anyone complain about to much power with a weedeater. I've always been real happy with its performance though.
For sure. We have husky stuff at work for saws and k12s. Hate them. Nothing but constant issues and new guys always flooding them. We're switching over to stihls finally
Brett
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #18
Brett
The FS 40 c-e I believe was the one I was looking at for $160, it was a curve shaft, the strait shaft weed eaters were $350 and up.
According to there website they carry the 91-131
Professional Trimmers For Sale in Circleville, OH 43113
I started out with Husqvarna chainsaws and liked them a lot, I just have better luck with the Stihl's.
I had to put a bit of money into it but I bought a used 05 660 magnum for $500 about 6 years ago, it had a worn out 36in bar and a shot 3/8 chain. I pulled the bar and chain off, took it into my local Stihl dealer and told him to go threw it, put on a .404 25in bar and sprocket, put on duel logger style bumper spikes and replace the cracked sprocket cover, I think all that was 200-300 bucks but the end result is the best saw I have ever ran, it's so balanced an smooth it's mind boggling.
I have cut idk how many cords of wood with it in the past 6 years, it cuts so straight I haven't even rubbed the paint off the bar. The .404 chain stays sharp a crazy long time, my cousin has 25in 3/8 bar on his newer 660, he can cut slightly faster than I can being he's not cutting as wide of a channel but my saw stays sharper longer.
Just last week I pulled them out, cleaned, greased and blew out the air filters and sharpened the chains, all time two fav saws right there. I have ran a lot of diff saws.
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #19
I just bought a Honda 4 stroke straight shaft brush cutter/weed wacker. Model HHT35SUKA.
Takes a 10" saw blade.
Haven't had much time to use it, so cannot yet offer a user opinion.
It is a bit heavier than a 2 stroke (15.4 lbs.), but has a nice harness, and is very quiet.
$389 on line, from Home page - MAXTOOL (free shipping)
Good product reviews too.
   / FULL SYNTHETIC 2-cycle engine oil in Stihl MS-261 chainsaw? #20
Probably new model numbers. Straight shaft is the way to go for sure. You really get a better product based on price unfortunately. That fs91 or any of its kin would be a good fit. I bought a 660 in 2013 or so. They are beasts for sure. I love firing it up around someone that has a small consumer grade saw and they are blown away at how deep it's idle is. Only run a 25" 3/8 chain on it. Chains stay sharp when you keep them out of the dirt. I can run a chain most of a day if I'm in pine, hardwood is a little harder on them. If I have a helper, they will go thru several chains. When they have to start paying for them they miraculously learn to run them right!
Brett
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
utv cart Honda (A56857)
utv cart Honda...
2019 Harley Davidson Electraglide (A55973)
2019 Harley...
2021 Ram ProMaster City Van (A56858)
2021 Ram ProMaster...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
