son's ford 9n
/ son's ford 9n #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
my son just got his late great grandfather's 9N and is tickled about it. I on the other hand have been tasked by my wife to get it running again and as our schedules very rarely work out I can't make it a bonding experience I just inherited another project. I bet Mr. Jack is smiling just knowing that his pride and joy of a tractor will have a new home and be used again.
/ son's ford 9n #2
Good to see a family tractor handed down. Looks to be in pretty decent shape visually...and at least parts are still readily available. Sure it will be treasured for years to come. Keep us updated on the progress!
/ son's ford 9n #3
It does look nice. Relatively easy to work on. Even got a push / brush guard on front. Wonder if that was factory? It'll be fun.:thumbsup:
/ son's ford 9n
Back at work today so no time to work in my shop, but yesterday after letting the battery charge for an hour I tried to crank it and finally got it to run about a minute but nothing after that so it probably has a gummed up carb.
I read a story a while back about the best wife in the world, well mine calls me at work today tells me I should sell my B26 Kubota and buy a new L47. I wonder what she wants :confused:
/ son's ford 9n #6
Tractor hand me downs are good thing,in this case Ford looks good shape and your son can learn a lot both on/off seat.
/ son's ford 9n
yeah, I will too because I have never worked on but one of these and I will include him every chance I get.
/ son's ford 9n #10
/ son's ford 9n
Thanks I will be looking at that link alot
/ son's ford 9n #12
Remember, those old timers have a positive ground...
/ son's ford 9n #14
That one has an alternator on it so it probably has been converted to positive ground and twelve volt. The only changes are an additional ballast resister, twelve volt coil and removal of the voltage regulator. Can't tell if there is an exciter wire on the alternator or if you just rev the engine to get it to charge.
/ son's ford 9n
yep it's 12 volt but I have not had time to investigate what all was changed on it.
/ son's ford 9n
UPDATE: got the old tractor running today and that was the only good news. found out the hydraulics are not working, in first gear it has a knocking sound and it has a cracked block right where the newer version has a freeze plug. it does not make the knocking noise in any other gear so it probably has a chipped tooth. the three point hitch does not even try to move.
/ son's ford 9n #18
The cracked block is the biggest concern. The hydraulic fluid might just be contaminated with water.
Is there any antifreeze in the oil? Was the cooling system filled with water and no antifreeze? If it has antifreeze in it now, and it is not leaking, then perhaps the block cracked years ago and it has held together OK as is.
I was given my great grandfather's tractor about 10 years ago (a 1943 Case SC tricycle type - about 25 hp). I used it as my only tractor up until 5--6 years ago. It is neat to have/use a piece of my family's history- now it sits in the barn but I start it/drive it every few years.
I'm sure your son will appreciate it, even if first gear is "off limits". Some day, replacing that gear might be a project that he can share with his kids.
/ son's ford 9n
the Hydraulic fluid looks a little milky so your are probably right, No antifreeze in the oil that I seen and when I topped the radiator off with water it turned green so it must have had some antifreeze in it. the block looks to have been welded before and it cracked right above the old weld. trying to decide if I want to have it welded or sell it to someone that might want to restore it or use it for parts.
/ son's ford 9n #20
If the crack was repaired in the past and isn't leaking now, then it may just be cosmetic at this point.
My two cents is to take your time on making the decision whether or not to sell. I'm glad my dad didn't sell my great grandfather's tractor.
Maybe Soundguy can tell you how hard it would be to fix the issue with 1st gear (he is the TBN member that seems to share the most knowledge about vintage Fords).
DSP 900 Balancer with Split Weight (A63689)
DSP 900 Balancer...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
