3032 2 bottom plow
/ 3032 2 bottom plow #1
logangrey
Western NY
LS 3032
I have a new 3032. Just wondering is it able to pull a 2 bottom plow or would that be over taxing the machine. It has 32.8 hp i believe or close to it. Any info apreciated
/ 3032 2 bottom plow #2
Only one way to find out.... hook it and book it. I'd guess as long as you don't try to sink it to China you'll be fine..
/ 3032 2 bottom plow #3
I can't tell from your profile picture if you have ag tires or r-4 but I'd be really surprised if it would pull it with r-4's. Also is this a 2-12 or a 2-18? Big difference in plows (I don't know if there is such a thing as a 2-18 but still)
/ 3032 2 bottom plow #4
In ground contact work, which includes plowing, horsepower is almost immaterial. What counts is tractor weight.
Form of tire is relatively unimportant relative to tractor weight.
((Turf tires are an exception; too wide to fit in a plow furrow. ))
Your LS 3032 is a little heavier than my Kubota L3560, which has air filled R4/industrial tires.
LINK TO tractordata.com: TractorData.com LS XR332H tractor information
You will have no trouble pulling a two bottom 12" or 14" moldboard plow in good condition, once you have plow CORRECTLY ADJUSTED on your Three Point Hitch.
A two bottom 16" plow, which moves around twice the dirt of a two bottom 12" plow, will not be so easy.
Never plow dry soil. The traditional time to plow is late Fall/early Winter. However, you can plow whenever the soil is moist.
Be aware moldboard plowing is an advanced tractor art. Not a skill quickly acquired; however plowing is psychologically rewarding.
If your New York soil is quite rocky, research Disc Plows before purchasing a moldboard plow. A Disc Plow is not a Disc Harrow. A Disc Plow looks like one, two or three discs from a PRIMARY TILLAGE Offset Disc.
LINK: TDP2 Series 2 & 3 Blade Disc Plows | Tufline
2022 John Deere 835M Gator (A63111)
2022 John Deere...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2017 Dodge Journey SUV (A61574)
2017 Dodge Journey...
2021 JOHN DEERE 844L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2006 PITTS 4 BOLSTER LOG TRAILER (A64276)
2006 PITTS 4...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
