Attachments you're glad you bought
/ Attachments you're glad you bought #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
We need this to compliment the other thread. Way up on my list is the Pats Easy Change, but they wouldn't be nearly as easy to use with out the Telescoping Stabilizers. I'm sure I'll think of some others.
/ Attachments you're glad you bought #2
Two are easy...
Tooth Bar and Belly Pan for my BX23
Both add a lot to the capabilities of this stout SCUT...
/ Attachments you're glad you bought #3
Best Attachment Ever = EA Wicked Grapple! :D
Second best = steering wheel spinner - and it's a close second...
/ Attachments you're glad you bought #4
#1 FEL
#2 Backhoe
Rare or almost never used. Gannon & post hole digger.
Two are easy...
The belly pan has saved my fan now for more than ten years. Another attachment that has been used and abused is my 3PH trailer mover with welded chain hook. I use it to drag trees out to use for firewood.
/ Attachments you're glad you bought #7
Bush hog, tiller, box blade, tooth bar, mechanical thumb, belly plates (too soon old, and too late smart...) Mark's adjustable 3-pt stabilizers...
Z.
/ Attachments you're glad you bought #8
In the order I bought them: loader, bush hog, Pats easy hitch, angle blade, tooth bar, * Mahindra tool handler, brody knob, Paumco quick spade, Rankin front loader forks, (adapted to attach to 3pt hitch for heavier loads). landscape rake with gauge wheels, canopy, back hoe, mechanical thumb added later. The thumb doubles the use of the back hoe, 3pt log splitter, pine straw rake.
*The tool handler is Mahindra's device which attaches to the loader arms, and allows a quick change of bucket or forks.
Things I've used the least: quick spade, angle blade. Things most used: loader bucket with and without tooth bar, back hoe, bush hog, forks, rakes, and log splitter.
/ Attachments you're glad you bought #9
2 is easy. Wicked Grapple and the brush hog
/ Attachments you're glad you bought #10
Well, if we're counting loaders, then I guess that's at the top of the list. After that, pallet forks, my Farmi 351 skidding winch, and this one I just brought home:
I'm very excited about that one!
/ Attachments you're glad you bought #11
All of them. Assuming the loader is a given the grapple and backhoe live on the tractor. The rest of the implements are useful a couple times a year.
/ Attachments you're glad you bought #12
Show off!! Really would like to have one, but then I'd need a bigger tractor with quick attach.
I have a Kubota L2501 with a quick attach on the fel would not have the tractor with out it. Have a log grappler use it a lot to move logs and brush works great for pulling vines out of trees too
/ Attachments you're glad you bought #13
Glad you like the Pat's, was glad to see you leave with them. :D
And front hydraulics unless you can run a line from the back if you have them in the back. Love the grapple.
Of course FEL with bucket, RatchetRake and Rip & Dig, boxblade, grapple, forks, PH Digger, tiller, bush hog (with current land), and have a new Kubota thumb off a BX25 for sale.
/ Attachments you're glad you bought #14
Hydraulic top link for use with box blade and slip scoop.
Third function valves for FEL use with grapple buckets and hydraulic angle snow plow.
SDT
/ Attachments you're glad you bought #15
Not counting the obvious like the loader or backhoe, it's a toss up between by bush hog that gets used all the time, or my grapple, which made life so much easier.
/ Attachments you're glad you bought #16
FEL is a given;by most used;bush-hog,front snow plow(FEL mounted),thumb on bucket,tooth-bar,rear blade,box blade.Roto-tiller in the spring ,not a ton of hours but the best tool for the job.
/ Attachments you're glad you bought #17
#1 - Steering wheel spinner
#2 - Piranha Tooth Bar!!!
Tooth Bar 1.jpgh
/ Attachments you're glad you bought #18
Loader, piranha toothbar, pats quick hitch w hodges stabilizers.
/ Attachments you're glad you bought #19
Other than the loader, Ratchet Rake! I love this thing. It pulls out brush pretty well and saturday alone I ripped out 5 stumps on the property that we used to just mow around.
/ Attachments you're glad you bought #20
I'd never heard of Pats Quick Hitch. That's cool.
