   / Harbor Freight Tools that don't suck #7,421
What thickness mild steel do you limit it to?
Mark, depends on how much time you have or how nice a hole you need/want. I use them in the drill press all the time. Awhile back I stacked 4 pieces of 3/8 flat bar parts I wanted matched up and it took about 30 minutes. Use plenty of that sulfur based cutting oil. You can stack and drill the pilot holes with a long bit, then un-stack. Most of mine are the deep ones. Be sure and put a piece of wood in the vise though.
I haven't been on this thread for a time. Did not know you were a regular. Maybe now I will have time to read all this esoteric stuff and watch your smoke.
Ron
   / Harbor Freight Tools that don't suck #7,422
Does HF have a decent drill press that will drill up to half inch steel ? Decent price? Garage use at home, not for a buisness.Thanks.
I have one of their older 16 speed bench mount. Drill 1" holes with it a lot (lowest speed) and good sulfur cutting oil. Have used 6" hole saws in it also (slow process)
Ron
   / Harbor Freight Tools that don't suck #7,423
I have one of their new floor standing 16 spd drill presses. It replaces the same older unit I sold when we moved up here. I too only use it occasionally in my home shop, and it does good for that. It will drill 1/2 mild steel just fine as long as you use a slow speed setting, lots of cutting oil and a slow feed speed.
If I was a production shop that needed a heavy duty drill press for constant production use, I would look elsewhere.
   / Harbor Freight Tools that don't suck #7,424
Just got a new catalog/flyer in the mail and they have a new roller cabinet with wood top, Yukon brand. Looks nice and only $289. Anyone seen one in the store? I have a a 25% coupon for Monday.... Might have to check it out.
   / Harbor Freight Tools that don't suck #7,427
I've been in need of a GOOD drill press and looking for years. Amazon and WalMart had been running a price war on Wen tools, cheap knockoffs similar to HF.
Well they had the WEN 8" 5-Speed Drill Press on sale for $35 a couple of weeks ago. Now it's back to $75 at Walmart and $82 at Home Depot. So I decided for $35 I could get that and wait on finding a GOOD drill press. It's got a bunch of reviews on Youtube.
They might start the pricewar again.
   / Harbor Freight Tools that don't suck #7,428
If that doesn't have more power than the HF $39 benchtop drill press I bought several years age - don't bother. Not only weak, but impossible to tighten the chuck sufficiently. That wasn't really a general shop tool. It was more like a specialty tool for an electronics lab or something that wouldn't need much force. I hope HF's current model is better.
   / Harbor Freight Tools that don't suck #7,429
Hmm.. About 7-8yrs ago I bought a 'managers special' at TSC of a 12" table top drill press and 6" bench grinder combo for $50. Both have been doing pretty good so far. I image the HF ones have caught up in quality since then... maybe.
   / Harbor Freight Tools that don't suck #7,430
HF typically excludes cabinets, tool boxes, etc. from Coupons.
Ford 8510 (A53317)
Ford 8510 (A53317)
Wright Stander X Mower (A57149)
Wright Stander X...
GENIE S-60 MANLIFT (A58216)
GENIE S-60 MANLIFT...
Giyi Pallet Forks (A57149)
Giyi Pallet Forks...
2020 John Deere 5065E 4 x 4 Tractor, S/N 1P45065EPLK406145, John Deere Diesel Engine, Cab, 3 Point (A59076)
2020 John Deere...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
