My 7 pin connector has no wire on pin #4, 5065e
   / My 7 pin connector has no wire on pin #4, 5065e #1
Rmd8136
Gold Member
Ft mill, sc
Deere 5065e MFWD
Troubleshooting my 30 amp ACC blown fuse on 2012 5065e. My 7 pin connector has no wire connecting to pin #4 located at 6 o'clock. According to the diagram in manual, pin 4 is "reserved/brake light". The red wire from tractor (presumably "hot", is connected to pin 7 located dead center. The manual labels this pin "accessory". When measuring voltage across the 2 stabs (holding fuse) I measure 12.8 volts from left stab to frame and 0 volts from right stab to frame. Also measure 12.8 volts across stab from left side to right side. This indicates a fault between right stab and frame (ground). I wonder if that 7 th wire for pin 4 never made it to 7 pin connector and is touching frame or ground? Just wondering if pin 4 is intended to be "not connected"? I intend to measure resistance between the "7 pin and frame to see if it is grounded. But if someone knows pin 4 should be connected to a wire, then that wire (somewhere in conduit) may be the fault if touching a grounded wire or frame.
   / My 7 pin connector has no wire on pin #4, 5065e #2
Picture?
What is the 7 pin connector used for?
   / My 7 pin connector has no wire on pin #4, 5065e #3
As far as I can tell , it is the only load on the 30 amp fuse labeled 30ACC. Mine has a short to ground on the wiring from the fuse block to the connector behind the fuel tank on back of tractor
   / My 7 pin connector has no wire on pin #4, 5065e #5
Pin #4, which is at the 6 O Clock position, is brake/stop light on my 7-pin connector. Mine definitely has a wire going to pin #4. And there is a wire going to each of the other six pins also. I just went out and bumped my noggin checking the back of the plug.
I think your assumption that the wire going to pin #4 has come off and is grounded somewhere is valid. Find the wire, re-pull it thru the conduit, attach it to pin #4 and that should solve your problem. Then try to determine why that one wire came off the plug in the first place?????
Thanks for the info. Is your tractor a Kubota? Or a Deere? I am hoping you are correct but wondering if the Deere could have an unused pin by design?
   / My 7 pin connector has no wire on pin #4, 5065e #7
should be universal as John Deere would not expect you to only pull Pull Deere equipment
I agree. On my tractor I have both a 2 pin male-female connector AND a 4 pin male-female connector both about 1 foot upstream of the 7 pin plug. Probably the 4 pin connector is the turn signals and the 2 pin a hot wire and ground. I guess the missing wire is another hot wire or wire connected to brake lights .
   / My 7 pin connector has no wire on pin #4, 5065e #9
Rmd8136 - my seven pin connector is on my Kubota. But the seven pin connector on my Ford F-150 is exactly the same and all pins provide connection to the same places on both the Kubota & Ford. I think the seven pin trailer connector is pretty universal.
   / My 7 pin connector has no wire on pin #4, 5065e #10
This is how my truck and trailer is wired:
Upright File Organizer (A54816)
Upright File...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
kohler generator (A56857)
kohler generator...
2016 Ford F150 Single Cab Pickup Truck (A55973)
2016 Ford F150...
