Kubota 47% -- John Deere 19%
/ Kubota 47% -- John Deere 19% #41
How do you get "INFLATED" market share by using number of units sold? From the replies to this thread you can tell who ones what brand by their replies. I have owned a lot of John Deere tractors over the years but they have shot themselves in the foot by not producing their own small tractors made in the United States. Also, they have forced many old, smaller dealers out of business and small rural areas. Instead of traveling 20-30 minutes to a dealer you now have to travel 2 hours to a dealer in my area.
Its clear that you don't understand how the number games are played. I would be more than happy to sit down with you and explain about how all those numbers work and how you get an inflated percent based on how you pull the information. It would create more confusion to go on and on about on here.
/ Kubota 47% -- John Deere 19% #42
It has sounded to me like the Nebraska test lab is a bit of a political tool in the tractor business. Deere funds it heavily. There are international standards and international testing labs that Kubota partisiptes with, but for some reason Nebraska chooses not to accept those results. I've heard its a very expensive and time consuming process to get at a tractor though their lab. Nebraska is not a huge market for the size equipment Kubota typically sells, so for them its made more sense to only run though the higher volume models and ignore the rest where they can't justify the expense. Every dealer has a Dyno, I can't tell you the last time I heard of any new tractor not turning at least its rated PTO HP. A company would be in court in a heartbeat.
Could you site the source where Deere funds these test heavy? Also which third party testing does Kubota use?
/ Kubota 47% -- John Deere 19% #43
Or maybe cite the site.
/ Kubota 47% -- John Deere 19% #44
I don't sell Kubota, in fact I sell against them. But I really doubt they fudge any HP numbers. We put one on our dyno occasionally and they will make rated HP.
/ Kubota 47% -- John Deere 19% #45
A couple things to point out, the weight of a tractor is what is going to make a tractor work. Extra ballast is very expensive, so you would have to have to add the addition cost of the "extra ballast" to the cost of the Kubota; which is still available for the Deere if you need it. If you decided to just cheap out and use water, you lose horsepower. A few years ago Kubota got into a lot of trouble with over rating horsepower and I believe they still wont take their tractors to Nebraska to have them properly tested by an independent company like most other color of tractors. Just something to think about.
Show me a tractor, regardless of color, that works to it's fullest potential with no ballast weight?? :)
/ Kubota 47% -- John Deere 19% #46
Dude, you are barking up the wrong tree. Messick has pretty impeccable credibility on TBN.
/ Kubota 47% -- John Deere 19% #47
There is difference in their philosophy when it comes to weight. Generally raw tonage is not looked at as a good thing. Its better to start with a lighter tractor and ballast it for the application than to be stuck with a heavy machine you can't setup right for the job.
I'd agree their cabs in the higher series lack the egronomic thought and high-end feel that a CNH or Deere tractor has. You can tell CNH uses automotive designers from Fiat in their stuff. The cabs are getting near car like. Kubota is not there, but they are generally quite a bit less expensive as well. M7 is better and shows they are capable of doing it.
The upside for Kubota is that they are HP for HP better for finish mowing because of their relatively low weight. The flip side or trade off is that they achieve low weight by having less metal and part of that metal is in the front axle. Well engineered but Kubota models often have lower rated loaders than equivalent HP tractors from manufacturers like Kioti and Mahindra. And, if you look at what you get for a given number of $$$$$, virtually every tractor manufacturer other than JD beats Kubota on loader capacity.
/ Kubota 47% -- John Deere 19% #49
I am not barking up anyone's tree. If your going to make a claim like that i would like to see some proof of the claim. If he doesn't want to prove what he claims about Deere buying off Nebraska test, that his choice. I am sure he is a great guy and just because I disagree doesn't mean I hate them.
/ Kubota 47% -- John Deere 19% #50
I don't own a kubota tractor but I have and I have owned second tier brands as well. I don't have a dog in this fight my only tractor is a 1980 Deere 4440 full size ag tractor but in the compact market kubotas are head and shoulders above the others from my experience. Yes they cost more but you get what you pay for. I ran a kubota this weekend that belongs to a friend that is 9 years old and has a lot of hours. It still runs like a top.
John Deere 6195R (A60462)
John Deere 6195R...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A59228)
2025 GIYI GY-SZYMJ...
2004 Volvo VNM S/A Day Cab Truck Tractor (A59230)
2004 Volvo VNM S/A...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
iDrive TDS-2010H...
2008 New Holland T2420 (A60462)
2008 New Holland...
