NH 1530 pto issues
   / NH 1530 pto issues #1
double hunter
Gold Member
Ford 1715
Just bought a NH1530, hst, runs great and everything works as it should but the pto will not stay engaged, I can hold pressure on the lever and it wiill stay in but you can feel it trying to jump out of gear, any suggestions
   / NH 1530 pto issues #2
I would check that everything is tight on the lever assembly, especially where I put an arrow. You may be able to adjust it to take out any slack as well since it shows a jam nut.
View attachment 1530 PTO Lever.pdf
I took the linkage loose and held the lever down with my hand and its still trying to jump out
   / NH 1530 pto issues #4
Previous owner likely shifted the PTO in without using the clutch. You have a couple rounded off gears in the rear PTO drive section.
Thats kinda what I'm thinking, just looking a the parts diagram it lloks like it can be accesed by removing the 4 bolts around the pto shafts,,any thoughts on this would be greatly appreciated before I dive into this
Just a follow up, took the transmission cover off and I have 2 gears that are pretty well eaten up, new gears on order should resolve this
   / NH 1530 pto issues #7
double hunter..... just bought a 1530 as well with the same issue. Is it a complicated fix? any suggestions? how difficult is it to remove trans cover? and where is it located? just bought a repair manual and can’t seem to find the steps. thanks
Just got thru with repair, I took the trans cover off, discovered the gears were stripped, replaced all the gears and and new bearing,,bout a 1,000 dollars worth of parts, works like a charm, not a real hsrd or complicated fix
   / NH 1530 pto issues #9
Hi I’m new to the forum. Do you have any pictures of the gears that you had to change. Mine is doing the same thing. I was hoping you took a few pictures of the job you had to do. I’d appreciate any info.
   / NH 1530 pto issues #10
Tractorforum.com has a post with pictures that will help you make this repair without splitting your tractor. This should work for all Ford/New Holland class II tractors, do a search on their site for TC29 pto jumping out of gear.
KUBOTA 80" QUICK ATTACH BUCKET (A51406)
KUBOTA 80" QUICK...
2013 Magnum Power MLG08 Towable Light Tower (A55851)
2013 Magnum Power...
2017 HAMM H51P PADFOOT ROLLER (A52706)
2017 HAMM H51P...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
