   / Harbor Freight Tools that don't suck #7,411
Sulfur probably causes cancer in California, at least in their mice. It makes cutting steel much easier. Sulfur is added to some steel to make it "Free Machining"
   / Harbor Freight Tools that don't suck #7,412
Interesting. I wonder why this plumber's thread cutting oil is labelled as a specialty product due to its high sulfur content.
Some things work best, and some things work well, and some things work... acceptably. If I were a machinist, doing a lot of work every day, I would probably want something in the "best" category, which is usually made specifically for a particular job.
But for a home mechanic... if I have some ATF around, I'll use it, and if not, I'll use motor oil or WD-40 or whatever oil is handy. I many be down in the "well" or even the "acceptably" category, but that's okay, I'm not making a living at this.
   / Harbor Freight Tools that don't suck #7,413
Me too. You'll chuckle at this: the high sulfur pipe threading oil I'm describing came from ... the free , recycle, table at the county hazardous waste collection facility. :D
They put out for reuse anything brought in that is legal to sell. I drive right by there often and have picked up paint occasionally, preferably rustoleum primer or topcoat for my implements where a few specs in the paint won't hurt anything. Here's a project that was 100% Rustoleum where only the final coat was purchased.
HF tools: I use the $9 HF spray gun, and thought I might crud it up with particles. But HF's cone filters work great to purify out the crust fragments from the several half-used cans of red primer I got there. After that recycled paint was filtered and thinned it sprayed identical to newly purchased paint. Hmm I just remembered - I sprayed flat black Alkyd paint that Dad must have bought 20+ years ago, repainting my trailer, and that took a month to harden where it couldn't be scratched easily. Paint of unknown history isn't for critical applications.
Last visit's prizes in addition to the threading oil were: A half gallon of pressure washer soap, and close to two gallons (across several containers) of pure tiki-torch and kerosene heater fuel. This makes decent 'diesel' for my old tractor after adding 2-cycle oil - which come to think of it came from there as well. (I don't run more than 10% of this bogus fuel in a tankful however). Also a couple of half-quarts of chainsaw bar oil. I'm not poor but I'm 'frugal' where opportunities like these are found. That's partly how I was able to retire early and live comfortably.
   / Harbor Freight Tools that don't suck #7,414
Ha! I love it! :D
My Kubota is currently running on #2 heating oil, picked up for free from a Craigslist deal. Guy was moving to electric heat and wanted to get rid of the oil tank, which was nearly full. Works for me! :thumbsup:
   / Harbor Freight Tools that don't suck #7,416
Just ordered a 25 inch 1/2" drive breaker bar from HF
   / Harbor Freight Tools that don't suck #7,417
That is a good purchase and I may have posted those comments earlier. I use mine almost exclusively where it gets abused. I stand on it, hit it with a big rubber hammer or do what it takes when I need to use it. So far, so good and in maybe 8 years it's only loosened up a little bit. The huge half inch ratchet is also good and while I haven't broken it, it keeps feeling like it wants to.
   / Harbor Freight Tools that don't suck #7,418
Heh. I managed to bend the handle on their 1" ratchet. A 5 foot cheater pipe and my 300+ pound son AND me leaning on it didn't budge the bung on my air compressor, but it did manage to bend the ratchet handle.
I gave up and solved my compressor problem a different way! :D
   / Harbor Freight Tools that don't suck #7,420
How in the world did you hold down the tank against that kind of torque? Long before that handle would bend, I'm picturing the tank flopping around like a dolphin that jumped into your boat. :eek:
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
Hydraulic Dingo Concrete Mixer (A55272)
Hydraulic Dingo...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EF3FKE19870 (A57453)
2015 Ford F-150...
12ft x 8ft Military Flat Bed (A57453)
12ft x 8ft...
DEUTZ MARATHON...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
