3016 hydronic filter #
/ 3016 hydronic filter # #1
Walter L
Gold Member
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
I purchased a used Mahandra 2013 3016 hydro W/FEL Tractor and no manuals came with it, I was able to download the user and operator manuals but it don't give me the engine oil and hydronic filter # or the procedure for changing the hydro filter. On my Kubota if I don't jack one side up when I remove the hydro filter I will loose hydro oil. Does this happened when I remove the Mahandra filter?
Thanks in advance for any help I can get on this.
/ 3016 hydronic filter # #2
Thank you rokit for the fast reply and links to the filters.
Walt
/ 3016 hydronic filter # #4
Don't know about your model but with mine when the hydraulic filter is removed all the oil drains so it's best to drain it before removing the filter. I have a shuttle.
The manuals aren't much good with Mahindra. Even the so called service manual doesn't give filter part numbers. I don't know about other brands but Mahindra documentation is an absolute disgrace.
Thanks Dick.
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2011 BMW 5 Series 528i Sedan (A61574)
2011 BMW 5 Series...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2008 New Holland T2420 (A62177)
2008 New Holland...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
1259 hrs (A61574)
1259 hrs (A61574)
