1700 Needs new muffler
   / 1700 Needs new muffler #1
reswhiz
CT
Ford 1700
Hi!
The muffler on my 1982 1700 has rotted off at the elbow. You can remove the entire muffler assembly off of the elbow, which is still in good shape. The guy who does my welding says it will just break off again, since he can't do anything but weld on the outside sheet metal.
I have checked with my New Holland dealer, and mufflers for the 1700 are just not available anymore. All of the aftermarket offerings I can find are Stanley made FO-35s. Problem is, the dimensions given on the Stanley website for the elbow, won't allow the muffler assembly to clear both the hood and the loader frame (too close or to far away).
If I could find an appropriate straight muffler, that I could clamp to my elbow, it would work fine. That, or buy the FO-35, and cut the elbow off and use my elbow (hate to pay for parts I just cut off).
Anyone have any suggestions?
Thanks!
   / 1700 Needs new muffler #2
Hi!
Thanks!
Do you have Tractor Supply near ,most any muffler that has the correct inlet size should work . On my 1300 I just ground off the rough edges of the old weld that broke and clamped on the new muffler . I think it was about $25 vs. $110 for the factory replacement.
Thanks for the reply. That was my fall back plan, if the original muffler wasn't fixable. I just wasn't sure about what size muffler the 2 cylinder 25 HP motor might need.
1605 (A57192)
1605 (A57192)
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2009 IC School Bus (A55973)
2009 IC School Bus...
