John Deere 110 TLB front auxiliary hydraulic blowing fuse
   / John Deere 110 TLB front auxiliary hydraulic blowing fuse #1
drware
Cleveland Tn
John Deere 110 TLB without backhoe, Case 580CK ,massey furgson 175 JD 1020
my front auxiliary hydraulic blows fuse when trying to use it any one having this problem
   / John Deere 110 TLB front auxiliary hydraulic blowing fuse #2
no, and I recently used a 110 tlb with phd upfront. without any issues over several weeks
   / John Deere 110 TLB front auxiliary hydraulic blowing fuse #3
No I have not. To resolve this problem you might try disconnecting the leads to the solenoid valve and see if it still blows the fuse when operating the joystick switch multiple times. If so I would look for a damaged lead shorting to the frame work. If it does not blow when the solenoid is disconnected I would also check the resistance of the solenoid valve and see if it is shorted.
Thanks I will try that
I just finished changing the two rocker switches and the joystick switch in that order. Now it will run my hydraulic hole digger in reverse but blow the fuse in forward. Do you know where to look for the solenoid valve?
Thanks Donnie
   / John Deere 110 TLB front auxiliary hydraulic blowing fuse #6
Did you try operating the machine in-between each component change?
If you change multiple items at once you can't know which has worked successfully and which hasn't.
:wrench:
   / John Deere 110 TLB front auxiliary hydraulic blowing fuse #7
Thanks Donnie
Do you have a skid plate/belly pan on this tractor? If so you may need to remove it to access the valves and solenoids attached to them. I will look for pictures to see if I can point out the specific solenoid location and wiring to check.
Have you checked for pinched or damaged wiring yet? The reason I suggested unplugging the wires to the solenoids was to separate and simplify the trouble shooting. With the solenoid unplugged if you blow a fuse it is probable that it is a damaged wire you need to repair. If you don't blow the fuse with the solenoid unplugged and repeated switch operation then check the solenoid contacts to see if the coil is shorted together. Let us know what the resistance is between the solenoid coil contacts.
I would not buy any parts such as these rocker switches without knowing the reason for it. Most switches do not short to the case or ground, most fail to make contact or remain open. These particular switches are housed in plastic which would eliminate shorts to ground and blowing a fuse.
It doesn't have a skid pan I haven't been able to find one. the switches where getting bad and the joystick switch was cracked badly too. When this started I was drilling a post hole
Thanks Donnie
   / John Deere 110 TLB front auxiliary hydraulic blowing fuse #9
I would crawl underneath and look for damaged wires. A skid plate is an important item for a 110tlb without it you can easily damage the hydraulic lines. I would make one if it were me.
do you know where I could a picture of one and measurements of one or anyone who builds them?
Did you find out where the solenoid location is for the front hydraulics is located
Thanks for all the help I'm slowly learning about these tractors
Thanks Donnie
CAT RM-300 (A50854)
CAT RM-300 (A50854)
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
12in Backhoe Bucket (A51039)
12in Backhoe...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2021 New Holland C327 Compact Track Loader (A51039)
2021 New Holland...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
