Thinking of a solar back up for well pump
/ Thinking of a solar back up for well pump #1
handirifle
Central Coast of CA
Massey Ferguson 1010
We are in the process of getting solar on our house, with a 14KW Lithium Ion (Tesla) battery backup, for power outages, mainly. The solar will provide 96% of our annual usage, compared to past electric bills. The battery is a iffy right now, the engineers are deciding if and how they can connect it to my main panel, since the panel is not connected (other than wiring) to the house. Plus the solar panels will be on the roof of my shop, that is currently neither electrically or physically attached to the house.
I originally priced out a system for the submersible and pressure pumps, with the battery, but it was way too expensive. There are some excellent federal tax credits and rebates available, making the house system affordable.
The company does not do less than 6 panel installs and that is way too much for the well system, so I was thinking of doing my own. Power outages here are not super frequent, but often enough, and in fire conditions, it can be out for days.
What I had in mind, is 2-3 100w panels with about 150ah of battery backup and a 220v inverter, since all my pumps are 220v. It would be a manual switch over system, that will lock out any possibility of grid back feed.
Has anyone ever done a similar project? I will do some more research, but the pressure pump will be the most common draw, and it cycles with the pressure switch, as need requires. It would only be for necessities, shower, toilets and kitchen use, showers being the largest use. We could take navy showers then, if need be.
I don't think 300w would fully charge the batteries if drained, but might keep them topped off. I would like to avoid a generator, if possible. Cost would be similar, (am hoping to keep it under 1K) but no fuel to maintain, (and a lot quieter) and once switched, I would not have to turn it on every time I needed water.
Thoughts?
I might add, both pumps are 220v, 1hp each.
/ Thinking of a solar back up for well pump #3
Can't tell from your description....is this too be a backup system for the well pumps, or do you intend it to run them full time with no grid tie ?
Why do you have two pumps ? Is there a reservoir that one pumps into and the other draws from ?
You'll need to get a good figure on the amount of time per day/etc that your pumps run to get a decent idea if the amount of panel/battery will handle it over a given period of time.
/ Thinking of a solar back up for well pump #4
Good questions that need to be answered to give meaningful advice. ^^^
Just off the top of my head I would think you need more than 150 amp hours of battery to run two pumps. Also remember that to get optimum use of the reserve capacity that a slow draw down over a 20 hour period is what most batteries are designed for. Drawing the power out of the batteries at a rapid rate will provide much less run time with reduced capacity. I would suspect the batteries will blow your budget and then some.
Sorry, thought I mentioned it. This is for power outages only. Those can range from a few hours to a few days. Definitely NOT full time or off grid, unless there was no grid.
We have 2 pumps because when we built (2010) we were required by fire dept to have emergency fire storage. In our case 5400 gallons, based on sq footage of house. We have the submersible pump that is 360 ft down in a 400ft well, and is located 560ft from the storage tank. The second pump is sized to provide 35 gpm constant at 50 psi constant, for the fire sprinkler system, we also were required to install ($5000). The pump itself is also a jet pump just like the submersible, to meet those specs. That was $1150 just for that pump.
The house pressure pump is my main concern, since we have the storage tank that the pressure pump draws from. The well pump only comes on when tank level demands it. In my case, when on back up, I would turn that pumps breaker off and only supply one at a time. If the outage lasted long enough to need the tank filled, I could turn off the pressure pump and run only the well pump till the inverter shut off due to low voltage.
All electrical controls and panels are located by my storage tank, so that will be easy enough. All are housed (now) in the shed I made from pallets, that I have a thread on somewhere on this site.
I am thinking 5 batteries at 35ah each would give me what I needed and that would stay in the budget easily. I am figuring a 4000w 220v inverter, and THAT is the big ticket item. Still have to shop around for that. The $1K might be on the low side, but I have other design ideas if this becomes too pricey.
Another thought was suitable batteries, an inverter, and a 110v battery charger. I could charge them up with my 2000w generators when the time came. In that case, I would eventually go solar and the transition would be easy. I do not want to have to rely on having gas or some other fuel, for worst case scenario. Out here that would be extended fire fighting. Those have taken power for a week or two at some locations. The fires take out transformers and short part of the grid, so it is shut down till repaired. That doesn't happen till the fire is out.
The home system is designed to provide power to the house automatically, so if on extended RV trips the fridge and freezer will be fine, and although the water system wouldn't work, that would have to be OK.
The pressure pump is intermittent, and I know the startup is the hardest. Running amps should be around 8 with a short surge to 15-20 on start. I have clamp on ammeters that I could easily test that with. Those are left over from my Air Conditioning repairman days.
Am I missing something?
Actually that would be enough run time for my needs. The pressure pump would be "as needed" which would be self restricted since we were on back up power. The longest run time of the pressure pump is during showers, or currently sprinklers (summer time only). In this case, the sprinklers would be turned off until back on the grid. The submersible, if I ran it for 2hrs would add about 1000 gallons to the storage tank. I'm not sure how much drop in tank volume it takes to kick on the well pump to refill. If the tank was low, I would turn off the pressure pump for the one day and let the tank refill.
There is only 2 of us living in the house, and showers would be 10 min each. I can take longer showers but in these cases I would shorten them, similar to when we RV.
Even during, say a 10 min shower, the pump runs about half that to pressure up the tank then shuts off. The cycling would draw power faster than constant running, but it is what it is.
Also, if I do add solar panels to this, they will be in constant state of charge during the day. The ones I looked at were $99 for one 100w panel. That is about an 8 amp per panel (at 12v, if I figured it right) charge so I figured about 3 panels ought to do it, with a good charge controller. The pump house is only 12ft long so I doubt I could fit much more on it.
In this scenario we would also be sure to shower early in the day, to allow a full day to recharge the system. I wished we could tie into the house circuit, then none of this would be necessary, with a 14KW battery, but I sure don't know of any safe way to do that, since they are each on separate meters.
/ Thinking of a solar back up for well pump #9
No way a 400w inverter will start and run a 1-hp pump. 1-hp is exactly 746 watts but by the time you add in losses etc you're really looking at 1200-1500 watts and 7x that for starting. I can tell you from experience that it requires a 3500-5500 watt generator to start a submersible pump ( quality matters).
I'm sure the company tried to sell you a grunfos sq flex? That is the system you want. It will run on 90-230 vac or 30-300 VDC. Lots of options for batteries etc.
Not sure what company you mean except maybe for the system that was too pricey? Couldn't tell you what equipment they were installing. Not sure what the square flex is.
If the sq flex is a solar panel, I have read flexible panels are less effecient. I know they do better in partial sum but with over 300 days of sun a year, thats not a big worry.
/ Thinking of a solar back up for well pump #13
If I were trying to get by during a power outage using batteries for a power source I would use the rv as it would require less power to function.
For a fresh water pump using your storage tank I would use an rv 12 volt pressure pump with automatic on off control. A single 12v deep cycle battery group 29 would deliver a lot of water for your use. It may not produce as much as you are accustomed to but you could learn to live with it. Pump, battery, battery box and charger would cost about $250 to $300.
I don't see how your math works for the storage batteries. Most deep cycle batteries should not be discharged below about 50% and that cuts the available power in half. Some of the expensive batteries such as Odyssey Extreme are made to discharge to 80% so more power available between charges. In short terms you need a real battery bank to supply a 4000w inverter if you intend to run pumps for hours a day instead of minutes per day. Trojan batteries come to mind and they are not cheap. 4000w /12v=380 amp load with inverter losses included. So the 175 amp hour battery bank you mentioned would last maybe 10-20 minutes before the voltage dropped below 10 volts.
Just my opinion and I have looked into providing mobile power in my work for long duration times the cheapest way to power 230 v pumps is using a diesel generator. My reasoning for this is because batteries are expensive and require replacement frequently enough to make the systems operating cost too high. Natural gas pipelines may be shut down during a major fire. Gasoline does not store well and large quantities are unsafe to have around a home.
jenkinsph
I get what you are saying but it would never be under a full load, as you described, but for more than a fraction of a second. During motor startup. If you read my posts carefully, you'll see it would rarely, if ever need to run the well pump, which would be the 2hr run.
My point is to avoid moving into the RV. If it were going to be a LONG term issue, that might have to happen but if I can get by for a few hours or few days without it, then I would. I also cannot fill the water tank on the RV without pressure, as it is not a pour in opening, it's a regular hose connection, requiring pressure to fill. So it would mean getting pressure somehow, or storing the fresh tank full for months on end, with the possibility of it getting bad.
Even if the system only gave me one hour total of run time, it would most likely suffice.
As for generators, even storing diesel fuel can cause issues. The crud in diesel fuel can gel and cause major problems. I know cause it has when I store it for my truck and tractor. If I went generator, it would be a dual fuel (gasoline and propane) and be connected to a spare 120 gallon tank I have. I just don't want to have to turn on a generator to wash my hands, or leave it running all day. That is the negative of a generator, it is not demand friendly.
I have no desire to walk 30 yards up a hill, in the middle of the night so I can flush a toilet.
I also thought of other ways by running a smaller 110v pump and using existing generators or batteries, but a 110v motor is less efficient and uses just about as much juice. The only advantage is a cheaper inverter. A large enough 12v pump is a closer solution, one worth considering, as it would eliminate the need for an inverter.
/ Thinking of a solar back up for well pump #15
jenkinsph
You can use VFD (variable frequency drive) programmed for a ramp start of the pump. That way you could get by with smaller inverter. They are cheaper than large inverter
I will have to research that one. Thanks
/ Thinking of a solar back up for well pump #17
jenkinsph
Here is a link to the Grundfos MQ pumps I have used and sold. They work pretty well and are soft start. These would still require a good power source though. http://us.grundfos.com/products/fin...oads/download_2/file/file.res/L-DWS-SL-02.pdf
For your needs I would still recommend a 12v rv pump and get by with that.
To run the existing 230v pump you speak of with 8 amps running that is still a 153 amp load at 12volts. That is a heavy load on a battery bank rated for 175 amp hours, too much in my opinion. If you must run these larger pumps I recommend you up the battery storage by about 5 times to 750 =1000 amp hours.
Well, personally 750-1000 to my thinking is way overkill. Would have been cheaper to go with the commercial bid, than hobble that together.
I have done some more reading and will post what I decide to build. One idea that caught my attention, was a guy that had a bank of batteries and used a 110v trickle charger to maintain them. Then he just ran them till they dropped off. I could recharge them with solar or a small generator. A second, smaller 110v pump was my very first, original idea, even a few years ago, that I could power with a generator, but I shelved the idea because I didn't want a generator running all the time.
/ Thinking of a solar back up for well pump #19
The solar/battery "need" is always difficult. The time of year/weather and uses are factors that only you can decide. Of course the power will go out on a stormy....yada yada yada.
Remember inverters are only 70-80% efficient. You will lose a lot right there. Also consider the amp hours for the draw. At higher draws you EXPONENTIALLY less usable power in the battery- batteries can only make power so fast. A factor for battery type and size.
It may be cheaper to figure a way to backfeed the well circuit or panel with the existing system. Maybe an extension cord or something similar. A dedicated system doesn't seem to be the best approach.
If it was me I'd add a hand pump to the well. They sit next to the existing pipe and can run a shower etc just fine. You typically back feed the plumbing via a hose bib. Their is a company in North Idaho that makes a nice one.
As I mentined before, the well is almost 600ft from the tank. This boy ain't pumping no hand pump.
2013 International WorkStar 7400 Altec Bucket Truck (A61568)
2013 International...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
LandHonor LHR-RF24 Ratchet Tie Down and Flatpack Toolbox (A60352)
LandHonor LHR-RF24...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
New/Unused Landhonor 72in Rock Grapple (A61166)
New/Unused...
