L6060 vs MX5800
/ L6060 vs MX5800 #11
. I have also considered a used m6800 two wheel drive and just leave the sprayer hooked up all the time.
I would give that some more thought, is there one available in your area? I am one to use older 2WD tractors for dedicated field use. Would it have enough traction?
/ L6060 vs MX5800
Traction is not a problem. I never use 4wd when I am spraying. And my tires aren't loaded. Having two tractors sure would be convenient. It seems like I am constantly changing implements. (Brushog, BH, & sprayer) Those used 2wd machines sure sell cheap. I have seen a couple m6800 with less than 1000 hrs for under $14,000
/ L6060 vs MX5800 #13
While Kubota obfuscates the specs, I believe the larger Grand Ls and the MX Series use the same engine block and same chassis.
Outfit from base is very different.
I usually change from one implement to a second most days I use my tractor. The telescoping Lower Links and pin adjustable rigid stabilizers ease and speed the implement change process.
/ L6060 vs MX5800 #14
You can easily drop a lot of money getting a larger 4WD tractor and still end up with one tractor changing implements all the time. With crops there is often a place for a high HP 2WD tractor. Homeowners on here have a different need.
/ L6060 vs MX5800 #15
Look up the specs for a M5660SU. Not as large as a M7060, a tad larger than the L6060. The downside this is an economy model and no factory cabs are available. This tractor is beefy and simple as far as tier 4 tractors can be. This might fit what you need.
/ L6060 vs MX5800 #16
I thought most orchards used "cabbed" tractors to get away from the chemicals.
/ L6060 vs MX5800
Yes a lot of orchardist use cab tractors. I just prefer an open station tractor. I don't like the bulk of a cab. And I hate dirty Windows. I am almost positive I would bust something off a cab within two weeks of ownership. I would rather have the hp doing work than running an air conditioner.
/ L6060 vs MX5800 #18
I'd go with the second tractor if it's at all in budget. Even with the minimal work I do I still wince a bit every time I have to drop a three point implement and hook up the cart or swap between implements. Just my :2cents:
/ L6060 vs MX5800 #19
NO doubt about it, the RIGHT answer is a second tractor, big enough to do the job properly.
SR
/ L6060 vs MX5800 #20
I agree, second used tractor. And a gear drive would probably solve your sprayer issues vs HST (which I assume the MX has?)
Regarding the L6060 and MX5800 the l6060 has alot more bells and whistles, but keep in mind, that cost you alot more money, and equally important is it's about 200# heavier to drag up the hills which may negate the few hours more it claims
2018 Dodge 5500 Bucket Truck 4WD (A61307)
2018 Dodge 5500...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
208320 (A58375)
208320 (A58375)
John Deere 7810 (A60462)
John Deere 7810...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
1009 (A61166)
1009 (A61166)
