Concrete strength
/ Concrete strength #1
yanmars
I have a chance to get some concrete that is 1 foot square, with 4 pieces of 5/8 rebar in it. It would span 7 feet over a drive way to let water under. Any idea what those concrete pieces would carry in weight. There would be 9 of them but the tires would ride on just two of them.
/ Concrete strength #2
How does a 'one foot square' hunk of concrete span 7 feet ?
/ Concrete strength #5
Placement of the rebar will be required to determine strength. Concrete strength is also required as well as maximum aggregate size.
/ Concrete strength #6
Is there any rebar installed transverse in the beam
Unless the concrete Is homemade the strength should be 3000 PSI minimum
Aggregate size does not factor in beam strength
/ Concrete strength #7
Maybe Egon was thinking of rocks being added as fill?? Aggregate size is standardized and should be appropriate for the PSI listed on the bag. We added plastic fiber to bridge abutments we poured.
/ Concrete strength #8
You could recess 3 on each side and pour a 4 inch cement cap to spread the weight over several "beams" . Or something like weight distribution over multiples.
/ Concrete strength #9
It would depend on what the concrete pillars were designed for...horizontal vs vertical load bearing, what is the source of the concrete?
/ Concrete strength #10
No enough information provided to make a determination.
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
2013 FREIGHTLINER Cascadia (A61307)
2013 FREIGHTLINER...
2011 Deere 50D (A60462)
2011 Deere 50D...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
