Crossing Mud and Standing Water
   / Crossing Mud and Standing Water #1
ransonjd
Rochester, NY
BCS 605
How much standing water and mud can a tractor handle? I have an access trail on my property. There are spots that have been under a few inches of water since January. The soil underneath is sticky silty to clayey loam. I just planted a couple hundred willows and swamp roses along the trail. I would like to mow around them to keep down the weeds and brush. How do you judge whether it's safe to cross the wet spots with a tractor? I don't want getting stuck to be the first thing I do with my new DK4510HS. Also, are there any tricks for avoiding getting stuck in mud, when you have to cross it?
--John
   / Crossing Mud and Standing Water #2
Tractors are prone to bogging all the way to the axles.
The only tips I can give are 1) 1/3 tank of fuel. 2) 4-WD helps. Removing the FEL entirely will lighten the tractor but I have used my FEL to claw my way out of near bogged conditions, so I leave mine on.
R1/ag tires give better traction in mud but not water saturated mud.
VIDEO: small tractor stuck in mud - YouTube
   / Crossing Mud and Standing Water #3
If you just keep moving, you won't be stuck. :)
Bruce
   / Crossing Mud and Standing Water #4
I can tell you from VERY recent experience, that even 4x4 tractors sink quickly when the ground turns soupy. LOL.
I didn't get stuck, but now have some 12"+ deep tracks thru what was supposed to be mama's future garden spot, and a very muddy tractor.
one trick, would be to try to avoid going over the same area repeatedly. The wet ground will get progressively more squishy and soupy the more you drive over it.
I would leave the bucket on the front, if you do get stuck, you can use it to assist in clawing the tractor out...
I am trying to get accustomed to the weather in Tennessee, where it seems to quit raining just long enough, to make it appear that I can get some work done, then it promptly pours buckets of rain for days again.
If you only have a few wet spots you HAVE to navigate, some old plywood or OSB put down will disperse the weight, but that is only practical for a spot or two.
Could dump some wood shavings on the wet spots. But again probably not practical for your purpose.
Safest advice is probably to wait until it dries up some, grass will still be able to be mowed later.
   / Crossing Mud and Standing Water #5
--John
Tractors will go in water usually until it's sucked into the intake but that's way extreme plus water will eventually get into your gearboxes doing that.
Mud is a different story but similar to water. Tractors will usually go in deeper mud than is good for them. Once you're rear diff starts dragging its pretty much over. Add an implement on back that's dragging in the mud and it will be stuck pretty good.
Most anyone that's ran a plow/disk/chisel has been stuck trying to get a field prepped. The smart operator stops before burying the tractor and gets help. Running one down into the mud onto the under belly is plain stupid and will almost guarantee damaged seals and mud intrusion into the running gear.
With that said, I ease into an area and when the tractor sinks to the rim I stop and back out. Past that point you not going to accomplish much except making ruts that will hold water longer and be deeper next time.
With a mower on back I'd stop soon as I started squishing mud up and wait for a better day.
With your new tractor I would be very cautious.
   / Crossing Mud and Standing Water #6
if it is to wet and making ruts. just do not go out! end of story. kinda silly to go out and mow. and end up making ruts that will need to be repaired and end up as mud hole / ruts for the next year till grass grows back in after fixing the spots.
R1 tires i would more likely venture out within reason.
R4 tires i would still be on the porch waiting for it to dry out good.
if you walk out and your own shoes are making wet spots / mud holes / ruts. it is to wet for sure. no sense messing up more. weeds/grass can grow tall, and be cut down latter with a couple times mowing over it to mulch it up better. and then takes a couple times of mowing after the high mowing to get the grass back looking half way descent.
ruts are a pain to fix. waiting and mowing later simpler.
if you have a truck with some tow hooks on front and/or hitch on the rear. make sure you have the cable/chains already for 20 to 40 feet. and drive out on it with truck. if you get stuck use tractor to pull it out and call it to wet. truck less likely to make major rutting.
on other hand getting tractor stuck = waiting longer time seating out in the mud till it dries, and pending on how bad you got it stuck, a larger tractor needed to pull it out.
with others FEL = awesome way to push backwards to get back out many times, and or pull you out forwards
if you drive in with 4x4 / MFWD on and you get stuck. you are stuck pretty good. if you drive in with just 2WD and get stuck, chance 4x4/MFWD will get you out.
i like notation of cataclsym notation if mud gets to rim. time to stop and back out. a little rut ya. but field / wide area were there is no road/driveway. ya asking for sinking further.
   / Crossing Mud and Standing Water #7
You would be AMAZED... As with anything, perform your maintenance according to your usage. Manufacturer's guidelines are minimum requirements for basic usage. Extreme duty requires a higher level of maintenance and inspection. A tractor will generally go until it can go no more, and do so damage free. It can shorten the lifespan of various seals and components to operate in extreme conditions, but that is to be expected and part of the higher level of maintenance and inspections necessary to keep the equipment in good working order.
You could park it in a climate controlled garage and just start it for a few minutes a day and it would last forever with virtually no real maintenance ever needed besides wiping the dust off and polishing it every couple years. In fifty years or so you can enter it in antique tractor beauty contests at the county fair and drive it in parades too. :laughing:
That sounds like fun ATV trail to get muddy on one hot day. :D
Would it be possible to add some stone to the path? Grass can grow up through the stone and the stone will eventually sink, but in the process it will firm up and raise up the path. Go over it a couple times a year with a box blade to level and smooth it back out as it settles.
This is what I've been doing for a couple years to build a new road on my property that was uneven, had mud holes in the low spots, and would get worse every time you drove across it. I added some larger stone to the larger holes, then spread some gravel. Drove over it trying to alternate my path slightly each time to mash everything I could as evenly as I could for several months. Once the tire paths were becoming the low points of the road, I set my box blade at a slight tilt and pulled it to direct the edge material toward the center. Then leveled it up and dragged it all out smooth and flat. First several times I was reworking it I also had to add additional stone to some areas, but now the past two times I've dragged the tire impressions out smooth, I've not had to add any gravel, all of my low/wet spots are gone, and the grass grows up through it like the rest of the lawn during the spring and summer months. Winter does wear it down to the gravel.
If it is something you want to mow, it is likely not something you want muddy tire ruts in. If you can jump around on the area and not leave wet footprints as you climb on your tractor, then it's okay. If you leave wet footprints, wait for a better day.
It's called getting broken in properly. For both, the tractor and the new operator.
<In my best Jeremy Clarkson voice> SPEEEEEEED!
   / Crossing Mud and Standing Water #8
Rice tires!
Bruce
   / Crossing Mud and Standing Water #9
How much standing water? I've gone to the bottom of the front & rear axle. I don't want to go any deeper and have to trust the breather tubes on the axles. This was a situation - fresh water, hard gravel bottom - where I knew there would be no difficulties getting out.
How much mud? I've had my tractor stuck on flat ground with around 3" to 4" of sticky mud. The R1 tires loaded up and were a little less useful than racing slicks. I was pulling a disk harrow - I raised the harrow on the 3-point and was able to drive out but I had to avoid the area until it dried out more.
If you have to cross a spot that is wet, muddy, swampy - and you manage to make it across - when you come back on the return trip - don't drive in the same tracks. Your first crossing tore the area up to some extent - coming back in the same tracks just might be your undoing.
If it were me - I'd be waiting for things to dry out before mowing. Why risk the aggravation........... Use your new tractor for some project that's on dry land.
   / Crossing Mud and Standing Water #10
You are not really stuck in mud if you still have fuel in the tank. When you are in the mud and without fuel, then you are truly stuck.:)
2023 Kubota Z252KH-54 Zero Turn Mower (A55315)
2023 Kubota...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2010 Toro Workman MD (A55973)
2010 Toro Workman...
2016 Ford Explorer SUV (A56859)
2016 Ford Explorer...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
