How do you eat with chopsticks?
   / How do you eat with chopsticks? #11
You are only moving the upper stick, with your index finger and thumb tip
   / How do you eat with chopsticks? #12
Once in my life I witnessed someone raised eating with chopsticks. He shoveled, he did not pick.
I eat with chopsticks practically every day. Chopsticks are used to pick food from the plate, to shovel/scoop rice, like a pair of scissors to shear soft food to smaller pieces, in short: anything you do with your forks.
BTW, Asian etiquette says do not use your chopsticks to get food from the serving plate, use the serving utensils. However, if the serving utensils are not available, turn the chopsticks around and use the blunt ends as the community ends to get your food. Do not put the community ends in your mouth, doing so will get you booted off my table.
   / How do you eat with chopsticks? #13
This is how I was taught to use chopsticks.
Stationed on Okinawa, about a million years ago...
:D
I learnt whilst visiting Japan too (Navy port visit). The only difference I learnt was to drop the 'bottom' one down one finger or on the pad of the middle finger. We'd then practice passing peanuts back & forth with the bar "hostesses".
   / How do you eat with chopsticks? #14
Should you keep the angularity of the two sticks reduced, you'd achieve a greater uniformed clamping force. As you acquire skill, you'll achieve a greater level of precision and can angle the chops greater to grab less uniform objects. It's not unlike using a grapple on your FEL.
It'll be OK, Grasshopper.
   / How do you eat with chopsticks? #15
"Stationed on Okinawa, about a million years ago..."
I spent 18 months there, courtesy of the USN. Torii station in 1975-'77. Lots of typhoons in that time. Lots of protesting outside the gates. Watching SR71's take off at Kadena AFB...breathtaking to say the least. :eek: yes, I learned to use the chop sticks fairly well. Shrimp fried rice is still one of my favorites. :D
   / How do you eat with chopsticks? #16
"Stationed on Okinawa, about a million years ago..." I spent 18 months there, courtesy of the USN. Torii station in 1975-'77. Lots of typhoons in that time. Lots of protesting outside the gates. Watching SR71's take off at Kadena AFB...breathtaking to say the least. :eek: yes, I learned to use the chop sticks fairly well. Shrimp fried rice is still one of my favorites. :D
I eat with chopsticks all the time, whenever I go to a Chinese or Thai restaurant, or if I make a stirfry at home. It has gotten to the point where I feel uncomfortable using other utensils with Chinese food. Try them out. It takes a little practice, but after a while you will enjoy using them, and you are less likely to over eat!👍
I eat with chopsticks all the time, whenever I go to a Chinese or Thai restaurant, or if I make a stirfry at home. It has gotten to the point where I feel uncomfortable using other utensils with Chinese food. Try them out. It takes a little practice, but after a while you will enjoy using them, and you are less likely to over eat!��
We're ordering out Thai this week from a wonderful place and I am getting chopsticks to use for the first time. The posts here have taught me a lot and I'm going to succeed at it. We should all learn to use them.
   / How do you eat with chopsticks? #18
Well, in time honoured TBN tradition I say "Pictures or it didn't happen!" (Video for bonus points!!!)
   / How do you eat with chopsticks? #19
Chopsticks aren't hard to use. Just learn to use them with the right type off food. Key point: you don't try to "pick up" rice with chopsticks. You pick up the carefully bite size chopped bits of protein and veggies with the chopsticks but you "shovel" rice. That is why rice is typically served in small bowls rather than on a flat plate. You pick up the bowl to your mouth almost like a cup of coffee, tilt it and then shovel the rice into your mouth. Works very efficiently. Use the chopsticks as described here by others as pincers to grab the bits of veggie and protein but shovel rice.
Ahh, come on. I'm learning chopsticks, not juggling. :laughing: How can I eat and photo same time? :licking: Is that a Navy thing?
Good advice. I'm going with Schezwan chicken with broccoli so I can start with the easy approach first. I'll save the soup for when I know chopsticks better...:D
Ford F-450 Utility Truck (A52128)
Ford F-450 Utility...
2016 GMC Terrain SLE-1 SUV (A50324)
2016 GMC Terrain...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2011 CATERPILLAR 303.5 D CR EXCAVATOR (A51242)
2011 CATERPILLAR...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
