Rotary Cutter What size rotary cutter for 40hp tractor
   / What size rotary cutter for 40hp tractor
UPDATE:
I just went and picked up my BB600X today. It is bigger than I expected, really well built. I am really glad I went with this size for the cutting I plan on doing. It fits the tractor well. I will be going through the manual tonight. Tomorrow I am going to do some cutting behind the house. Here are some pics of the cutter:
   / What size rotary cutter for 40hp tractor #32
Man, that glare from the shiny objects in your pictures makes it hard to figure what's there!:laughing: Too nice looking. Get it out and get it dirty!
Quality never goes out of style. You're set!:thumbsup:
Regarding traveling speed, if one is cutting larger stuff one is going in reverse. I for one have a neck that's suffered from driving in reverse at speeds that one probably shouldn't: because a tractor and implement can do it it don't mean that you should;) But going forward, in grass, I generally have no issues running running in medium gear at near-full speed (unless I encounter my neighbor's wicked grass or, hopefully never again, my 9' tall grass!); I do, however, have a lot of trees, so slowing down always has to happen.
   / What size rotary cutter for 40hp tractor #33
Nice cutter that is a good match for your tractor. You should get many enjoyable years out of that unit.
Yeah, it won't stay clean for long. I am also used to the neck turning all day especially when I am using the grader box a lot. I have about a acre of tall grass/straw and shrubs out behind the house. I am going to get used to it by cleaning that up before I take it down to my new property. I have used my Granny's BB60 a lot in the past so I am familiar to running rotary cutters. But this thing is like the BB60 on steroids. I am going through the manual right now. I always like reading the manual front to back.
   / What size rotary cutter for 40hp tractor #35
UPDATE:
View attachment 507632View attachment 507633View attachment 507638
I have the same mower. Warning: the paint is gonna fade. I barely recognized yours as the same. Great mower.
   / What size rotary cutter for 40hp tractor #36
I would want to cover the width of my tires. Your tractor will run the 6' cutter.
6'. No contest.
I have a 6' on my L4330, about a 41 hp/36 hp pto and I wish I had gone with a 7 footer.
Heavy stuff, going up hills etc.; simple, just a shorter cut, less wider cut, slow down or some combination. With the wider cutter, you have options. With the narrower 5
cutter, good luck getting it to cut 6' wide, ain't happening.
6'. No contest.
I really thought very hard about going with the BB720X and initially that was what I wanted to do. I even called Woods directly and talked with their technical staff about this. I explained what I would be using it for and told them the make and model of my tractor. Their recommendation was the five foot cutter. Plus I did not have the cash to up it to the BB720X (this was ultimately what made my decision for me). Those two items led me to the decision I made. I am happy with my purchase and this cutter is definitely better that what I had before (no rotary cutter). If in the future I decide to get a six foot cutter I will sell this one or trade up. Thanks again for all the responses.
2006 CATERPILLAR TH460B TELEHANDLER (A55745)
2006 CATERPILLAR...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2011 INTERNATIONAL PROSTAR (A55745)
2011 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
TANK MANIFOLD (A55745)
2009 Utility Trailer Mfr. 4000DX 53ft. T/A Dry Van Trailer (A55852)
2009 Utility...
