Turn signal woes (or how not to get hit by traffic)
/ Turn signal woes (or how not to get hit by traffic) #1
Magicman710
South GA
JD 5220, JD 5055E, JD 5085E, JD 5100E
In the course of the past several weeks I have almost been sideswiped 4 times by vehicles while trying to make a left hand turn off of a paved road. Today was the first time a semi truck tried to do it. I have been traveling with tractors on paved roads for years, but with the acquisition of more places to tend, I'm having to travel on busier highways more often.
The situation is always the same. I have flashers on. Vehicle gets behind me. I turn the left turn signal on 100-200 ft before the turn. When I start slowing down, or when I'm right about to turn left, they pass me. I always make sure to check because otherwise they would hit me. In one instance I a car fly around me after I had started the turn! I had to jerk back into my lane to avoid hitting them.
I think the problem is that people are so concerned about getting a chance to pass me that they no longer even look at or notice the light pattern. They see me slowing down and think "GREAT, a chance to pass!" They don't notice that the lights have gone from just flashing to one side flashing and other side not.
I don't think hand signals would be any good. Me pointing or gesturing to my left would probably entice the drivers to pass me more, with them thinking that I'm saying for them to pass.
I've thought about just not using the flashers and just rely on the SMV emblem(s), that way when the turn signal is put on it'll be apparent to the drivers that are following. Or possibly turning off the flashers for a few seconds before I turn the signal on, so that it grabs attention that the pattern has changed.
Just looking for any pointers or suggestions by folks who may have had or are having the same issues of what I could change or do better.
/ Turn signal woes (or how not to get hit by traffic) #2
I have a related problem with city buses when I go to town. When they stop, both of the signals flash, but when they want to pull out left into traffic, the right signal stops flashing. The left never changes. Makes it harder to notice.
Bruce
/ Turn signal woes (or how not to get hit by traffic) #3
Use your arms just the way you were taught in drivers school.
Don't go waving or pointing!
Up is right, OUT is left.
Keep your head on a swivel! If you think driving a tractor is tough, try a motorbike!
/ Turn signal woes (or how not to get hit by traffic) #4
I know what you mean, you better be watching your back when you make a LH turn. I don't think most people even know that a tractor has turn signals. Your lucky these days if they even pay the flashers any attention. They are only focused on one thing..... getting around you as quick as possible no matter how.
I always try to have someone following my equipment when on the main roads. Just before making a LH turn, they will cross over an block anyone from trying to make a wild pass. You won't believe how many times we have cut someone off.
Sometimes it's just not possible to have someone following, so when I'm our there by myself I keep a very close eye on the traffic beside me. If I'm going to make a LH turn, I do about the same thing, start easing over before the turn. They seem to figure out that you are about to turn and will back down.
/ Turn signal woes (or how not to get hit by traffic) #5
I would say, that the speed of the flash when you put your turn signal on would help.
I'm not sure what they're called but I remember reading about Harley motorcycle drivers that install a kit to pulse the tail lights and headlights to best get the attention of drivers.
My thoughts were if you installed a similar kit on just your turn signals only, and let's say you set it to where it would fast flash when you hit your turn signal on that might grab the attention of drivers more that the signal speed has changed there for that your signal has changed.
And I second the motorcycle bit.
/ Turn signal woes (or how not to get hit by traffic) #6
I did that last month and almost had somebody T-Bone me. They passed on the left while they flipped me off and laid on the horn as I was making a left hand turn with my left turn signal on after having gone from hugging the white line to sitting on the center line when I put on my turn signal.
I used to try to be nice to cars and let them go by, but after several such incidents, I make sure to take my fair share of the road and let them worry about getting by me.
Aaron Z
/ Turn signal woes (or how not to get hit by traffic) #7
I always look backwards before turning left but I've never actually had anyone try to pass as I was turning.
/ Turn signal woes (or how not to get hit by traffic) #8
I can imagine how dangerous it must be. Fortunately I NEVER have to drive the tractor on any public roads. Its certainly bad enough when I ride my motorcycle.
/ Turn signal woes (or how not to get hit by traffic) #9
Lots of good points posted. I agree that most drivers don't notice the change from flasher to turn signal, and they likely don't realize tractors can have turn indicators. Most of the roads I am on are lightly traveled, so I rarely encounter the left turn problem. The rare time I am turning left with a car coming up from behind I either move father left ahead of the turn, or slow down and move to the right shoulder until they pass. Either way.... I assume they are going to be reckless.
An accompanying vehicle would definitely help in making turns, but it seems to aggravate drivers by making passing more difficult when it would otherwise be safe.
/ Turn signal woes (or how not to get hit by traffic) #10
I use flashers hand signs even try to glance back to make eye to eye if I can,than go w/my gut feeling.
3 type of drivers out there...common sense,little common sense,lack of common sense.
/ Turn signal woes (or how not to get hit by traffic) #11
I have a question. Is the turn signal actually working with the flashers on. I have to turn off my flashers to use turn signals otherwise both keep flashing.
/ Turn signal woes (or how not to get hit by traffic) #12
Get some LED flashers with arrows. The bigger the better.
/ Turn signal woes (or how not to get hit by traffic) #14
Seems that drivers everywhere are pretty much the same in their reckless, impatient driving habits. I added a rearview mirror to allow me to keep an eye on traffic approaching from the rear. That at least let me monitor what people were doing much better than turning my head every couple of seconds.
The flasher/turn signal thing does seem to be confusing for drivers. One thing I've tried that seems to help is to reduce speed a bit when activating the turn signal. That forces someone who is following to also slow down and often seems to break their "target fixation" on passing you just enough they will notice the turn signal, the fact you are edging to the left and maybe using your arm to signal a turn. But that only works "most of the time". There are some drivers who are so oblivious to the situation, their behavior is nothing short of erratic.
I kind of like the idea of a really large, bright LED-type turn signal... something like what's used on schoolbuses, for example, that isn't using the same light unit as the 4-way flashers.
Undecided whether an escort vehicle helps or makes it worse. I've had both experiences.
It's also largely undpredictable just which drivers and vehicles are going to be cautious and which will be reckless. Big rig operators mostly tend to be cautious, soccer moms on cellphones, not so much, young dudes in pickups are usually in a hurry, as are workmen on the clock, but don't ever take for granted you've figured out what someone is going to do!
/ Turn signal woes (or how not to get hit by traffic) #15
I do think the flashers mask the turn signals (even if one is disabled) - just doesn't look different enough.
If there is no oncoming traffic, I start to ease my tractor into the left hand lane so it is obvious I am turning. by the time I get to the intersection, I am full in the left hand lane so they can pass me on the right. That's an old school farmer turn signal.
/ Turn signal woes (or how not to get hit by traffic) #16
My advice: own the lane when you're in it, and own the road when you're turning. Don't give them room to pass, or they will try. Unfortunately, no one is looking at your flashers or turn signals for more than a second or two when they first see you and think, "Oh, crud, I'm behind another tractor." After that, they are only looking around or through you to see the first opportunity to pass. Most people are impatient drivers at best. You learn a lot about bad drivers and how to spot them riding a motorcycle. These lessons apply to tractoring on roads, too.
/ Turn signal woes (or how not to get hit by traffic) #17
And it sux more when snap something on an implement jerking it back or a long behind plow implement manages to gouge ur tire
/ Turn signal woes (or how not to get hit by traffic) #18
Agree, drivers are more aggressive recently. I have noticed that when someone has flashers on, folks want to pass. When the turn signal is on too long, they ignore it and think the driver just forgot it and pass anyway.
/ Turn signal woes (or how not to get hit by traffic) #19
Not that you should have to, but maybe pull off on the right side, then cross the road as if you were just on the other side once traffic clears?...
I agree about turning the flashers off, then the blinkers on. I also agree with owning the road that you're on.
It amazes me how butthole-ish people are. I drive a lot and "make time" plenty, pass plenty, and all that, but it can be done reasonably and safely. I've been flipped off for passing someone on the expressway and merging in front of them. I'm not a city driver either, so it wasn't a tight merge. Literally couldn't figure it out. I had to laugh.
Part of me sure says "run the SOBs over", but that won't work either. =)
Good luck.
/ Turn signal woes (or how not to get hit by traffic) #20
I am one of those impatient driver that will blow your doors off, but I refuse to pass anybody or anything at a driveway or intersection, just because you don't know the intentions of the person being passed.
The other thing too is most younger people don't know what the hand signals are. They are not taught any more in most drivers ed classes.
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
UNUSED KJ K2010 HEAVY DUTY CHICKEN COOP (A60432)
UNUSED KJ K2010...
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
