Overfilled with hydraulic oil - should I drain the excess?
   / Overfilled with hydraulic oil - should I drain the excess? #1
finnfarmer2
Southeast
Kioti CK35 HST
Changed the hydraulic oil on the CK35 HST and overfilled it. The manual says the capacity is 7.93 gal, so I poured in 8 qallons for good measure. Checked the dipstick and it shows about 1.5" above maximum. Will the excess oil hurt anything or should I drain some out? I haven't run the tractor yet except for a few minutes. Right now I am leaning towards draining the excess and save the oil for the next oil change in 400 hours. What say you? Thanks!
   / Overfilled with hydraulic oil - should I drain the excess? #2
would say remove excess. expansion/contraction of metal parts and like. and oil needs some place to go. also any sort of hills and like and fluid spilling out due to excess.
   / Overfilled with hydraulic oil - should I drain the excess? #3
Yupp if you have already ran it to fill any voids and you checked it per the manual, yes you need to drain some.
I pumped out 2 gallons and now the oil level is half-way between Min and Max. So, for the next hydraulic oil change I'll put in 6 gallons to start with and adjust as needed.
   / Overfilled with hydraulic oil - should I drain the excess? #5
:thumbsup: Thanks for the followup
   / Overfilled with hydraulic oil - should I drain the excess? #6
I would check on the oil level every couple times the tractor is used for a few times in case extra voids fill up and use oil.
   / Overfilled with hydraulic oil - should I drain the excess? #7
Now, here is the "why". The spec calls for 7.93 gallons. And I am sure that is the correct amount that it takes to fill the reservoir. BUT, when you drain a reservoir, you NEVER EVER get all of the old fluid out. You only get "most" of it out. The 7.93 gallons is when the reservoir is completely dry when it was assembled, or if you totally disassemble the transmission and remove all of the parts and dry it all completely out.
   / Overfilled with hydraulic oil - should I drain the excess? #8
I've just had the same problem. I even used all 3 drain plugs. And that little dipstick is worthless. I tried to ease up to full and BLAM! it was overfull.
I guess I'll pull one of the little axle drain bolts and try to pull out a quart.
I wonder if I could suck it out through the fill tube. (BTW I poured the drained oil into the old pail and there wasn't even close to what the spec said capacity is.)
Everything I do one the tractor points up how crappy the manuals are.
   / Overfilled with hydraulic oil - should I drain the excess? #9
Did you run the tractor for several hours? You need to run it to work the trapped air out. Then check again.
   / Overfilled with hydraulic oil - should I drain the excess? #10
And check with everything in same position. Ground 3pt, ground level bucket.
You think the hyd fluid dipstick is sucky? Check your front axle...... :)
John Deere 515 Grain Drill (A59225)
John Deere 515...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
New/Unused Electric Golf Cart (A57453)
New/Unused...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
