Oil & Fuel Trouble getting fuel to injectors 4010 hsd
   / Trouble getting fuel to injectors 4010 hsd #1
BH1
Big Lake, Minnes0ta
Mahindra 4010 Hydrostatic
Ran out of fuel. Refueled and changed the fuel "element". Tried bleeding the injectors but now no fuel nor bubbles coming out injector. Please advise. Also anyone have parts print? Nothing in the manual covers the injection system. P1070602.jpgP1070600.jpgP1070601.jpgP1070602.jpgP1070600.jpgP1070601.jpg
   / Trouble getting fuel to injectors 4010 hsd #2
   / Trouble getting fuel to injectors 4010 hsd #3
I'm not so sure you have to bleed the injectors. If it has a lift pump ( turn key on ) open the bleed screw until air quits coming out if gravity no need to turn key on. Then turn it over a few times until it starts 12 sec. at a time to avoid burning up starter.
   / Trouble getting fuel to injectors 4010 hsd #4
I
I have a Mahindra 2815 Hydro stat and I am not getting any fuel out of the injectors pump does anyone have any idea what I need to check on this
   / Trouble getting fuel to injectors 4010 hsd #5
jofox.. did you bleed the air out AT the inj. pump fuel inlet pipe.. MAKE SURE you have fuel going INTO THE PUMP..
Loosen the lines AT THE INJECTORS.. & spin the engine.. any fuel? if not.. Does it have an electric shut off solenoid?? does it shut off w/ the key switch or a pull cable?? if its a key switch, it has an electric sol. that controls the injection pump control rack.. those solenoids go bad ALL THE TIME..
If the solenoid is good, then the control rack in the injection pump is stuck in the shut off position.. & usually requires removal of the pump to free it up. 99% of the time.
   / Trouble getting fuel to injectors 4010 hsd #6
Thanks for the info but I need to know where the solenoid switch is located on a Mahindra 2815 if you know please let me know thanks
   / Trouble getting fuel to injectors 4010 hsd #7
If you can snap a pic & post it or send it to my home email, I can point it out..
My home mail is my screen name w/ at a o l dot com after it.
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
2015 Chevrolet Silverado 2500HD (A52128)
2015 Chevrolet...
