lostcreekranch
Super Member
- Joined
- Dec 14, 2012
- Messages
- 7,948
- Location
- Austin County, Texas
- Tractor
- NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
55 going to low seventies, cool overcast day.
errands this morning, then stuck here all afternoon and evening enduring the miseries of GI prep.
Black coffee and jello for breakfast. Yum.................
Almost every day in the next week shows good possibility of Spring showers. The fescue I planted in the nut orchard is growing about an inch a day, the day after I mow it looks tall. No fertilizer either. Happy to report that every one of my fifty hybrid willow trees has sprouted little bright green leaves all over. Everything gets watered pretty heavily at least once a week regardless of the rains. I did most of the watering yesterday, went through 100 gallons. Another 50 gallons today and I'll be done. Battery for pump on charge overnight, that tired old tractor battery is really working hard. I think the desulphate function of the smart battery charger has given it some new life. 750cca, replaced it with a 900cca.
I've been brainstorming on how to redesign my water wagon with what I have on hand. Turning on the pump with alligator clips on a battery is lame, though effective. My intentions are to take the much more powerful 7gpm variable speed water pump I bought for my motorhome and never installed, and use that for the water wagon instead of the small 12VDC pump I have now that runs constantly and thus runs the battery down. The new pump will only run as fast as the demand, so once I let off on the nozzle trigger, the pump will fully stop. I need to get that pump, plus a waterproof on off switch, and mount all this on a piece of plywood cut to fit in the little green JD cart. This water cart has made my life so much easier already, and I'm likely to need it for a number of years. So makes sense to do it right.
Another project....job security for sure.
Drew, I have a 25 gallon sprayer with 12 volt pump that I put in the bed of our Polaris Ranger. I bought the below 12 volt switch and remote control to turn the pump on/off. It really works well and will handle 20 amp load.
Fimco 12 Volt Wireless On/Off Remote Control 7771938 by Fimco Industries for $17.97 in Sprayers - Accessories - Spraying - Tractor Parts & Accessories - Agriculture : Rural King
