Fenceline trimmer
/ Fenceline trimmer #2
/ Fenceline trimmer
/ Fenceline trimmer #5
If you really want to get with it, they make Round up that will last for a whole year and keep stuff from growing back! Although when I used it, there was more like 8 months before stuff started growing..... still better than trimming all the time.
/ Fenceline trimmer
I have two acres fenced in around my house that's plank fence. I really don't want a brown line of dead grass around my yard.
/ Fenceline trimmer #7
all my fence lines, have wire running all the way down to the ground. so no use for me. but looking at original video you posted. and remember what i have looked at over the years "attempting to find a trimmer", that DR. trimmer, does not look good to me. the 3pt hitch trimmers for fence lines i do remember, had a much longer "guide bar", that to me would not catch on a post if you ended up to close to the post. that round disc DR is showing. seems like the posts will end up taking a beating errr "cutting" almost, result leaving a grove at bottom of post.
the couple trimmers i do remember "flipped around" the post. to make sure both sides of post was cut, and then reached around a bit more to cut all 4 sides of the post. (no need to take a pass down one side of fence, then go around to other side of fence and make another pass.
i do not remember the name / brand. it had a simpler "spring" action to go around posts. and it simply followed the ground. no need for tilting it manually or through hydraulics.
/ Fenceline trimmer #8
I have the (DR) one you pull with your lawn tractor, use a 46" Husqvarna Hydro. Overall I am happy with it. I think the spring should be stouter as sometimes it takes longer that I'd like to return to the fence row than I'd like. Course if I ran it slower down the row it probably would do ok. I Installed a chain (bypassing the spring function) for awhile but besides sliding sideways, which is not a problem, the thing gets hung up on T posts and strand wire if the strands are too close to the ground...like when clay shrinks the posts fall and the bottom rail gets lower and lower......
I put out a combo Glyphosate and 2-4-D as the combo works better than just the Gly.. Let it kill the weeds and then come by with the trimmer. Where there are no weeds, just grass, I omit the chemicals and just use the trimmer. I'd buy it again.
/ Fenceline trimmer #9
Go to your local farm fertilizer application business and ask for some Rinse Water....yea you will have DEAD Grass under your boards, but it will go away, after a couple of sprayings it will only be dirt. Or you could buy a weedwacker and do it the hard way. I have a 12" wide strip of Nothing under my fence, I am **** bout it tho. I spray it so the grass edge is straight and looks good.
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
2009 International 4300 Digger Derrick (A62613)
2009 International...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
