RTV 500 vs RTV 900
   / RTV 500 vs RTV 900 #31
iirc the 900's were a bit funky shifting, they needed the brake stepped on to relive pressure and blow shifting. depending on the age, updates and adjustments, some will hit the internal relief valve brake and slide the rear tires just by lifting the foot off the throttle.
I thought you had it figured out, but by the time I finished reading I realized you did not. :D
   / RTV 500 vs RTV 900 #33
On loose gravel or snow a fast lift off on our 2006 RTV900 lifting off the throttle in 2WD will slide the rears, same as old snowmobiles.
I believe that is normal for the older ones. There is also the pressure relive pull knob that you have to pull if the transmission has any load on it when you shift. In any case, you just learn to drive smoothly really quick.
See Post # 23 of http://www.tractorbynet.com/forums/...hat-does-your-tractor-cost-3.html#post4740751
   / RTV 500 vs RTV 900 #34
Lifting your foot off the throttle should not slide the tires.
It's simply an HST system. An HST tractor would slide the rears too if the weight were distributed as the RTV is.
   / RTV 500 vs RTV 900 #35
Mike, I didn't like the sudden stops. I added a Coast Valve. I prefer to use the brakes to stop if needed.
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
John Deere 5075E (A53317)
John Deere 5075E...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
2016 Freightliner M2 106 Altec AM50 50ft Bucket Truck (A55852)
2016 Freightliner...
