NH T1510 is hard to shift
   / NH T1510 is hard to shift #1
woody11
Merrill, Oregon
8N Ford guess I should add NH T1510
My "new to me" NH T1510 shifts hard but not always. The Hi, Med, Low works fine I guess. Am I supposed to use the clutch when shifting the Hi,Med,Lo? The reason I ask is that it seems to work fine w/o clutch. It's the 1,2,3,R on the stick that doesn't always shift easily and sometimes grinds going into gear. I did adjust the clutch linkage a little because when I got it the freeplay was a little in excess of what the book says. It's now "within range."
Mebe I should give a little more info on this tractor. It's a last year T1510 (2012) that was being reposessed when I bought it from the original owner. So far as I can tell the 1st owner took it home and used it but not hard. However, I believe the only maintenance he did was to change the engine oil and filter once at 65 hours. Nothing else. When I took it home it had a little over 770 hours on the meter. I'm still in the process of doing the maintenance including replacing some grease zerks on the FEL that wouldn't take grease. Frankly I'm surprised it ran as the fuel filter was so clogged I had to scrape the crud out of the sediment bulb. Regards, Woody
   / NH T1510 is hard to shift #2
I always use the clutch. Don't know if I have too. Sometimes it seems hard to shift , hit the reverse and forward peddle seems to assist it to get in gear. I only have 325 hours on the t1520 .
PumpJack Brand Pump Jack (A55315)
PumpJack Brand...
20' FIELD CULTIVATOR SPRAYER (A57192)
20' FIELD...
PALLET OF QUARTER FENDERS (A57192)
PALLET OF QUARTER...
LANDHONOR BS-12-2500G (2) PRONG HAYSPEAR (A57193)
LANDHONOR...
2011 Ford F-250 Crew Cab Pickup Truck (A55852)
2011 Ford F-250...
WOLVERINE TF3-66-2600G PIN ON PALLET FORKS (A57192)
WOLVERINE...
